Custom lighting
Old Apr 5, 2004 | 08:41 PM
insayne's Avatar
Car: 1984 Mint Z28 H.O.
Engine: 305 H.O
Transmission: 4 Speed Auto =| gettin megashifter
Custom lighting
i need to know where to buy just single LED bulbs and how to wire em up, im going to drill into the back of an old headlight and inserte some LED bulbs, and im going to do the same with the rear lights in a design so they shine through the blackouts.
Old Apr 5, 2004 | 09:30 PM
89Warbird's Avatar
Car: 1989 GTA Nighthawk
Engine: 389 CID TPI
Transmission: TCI 700R4
Axle/Gears: 9 bolt 3.23
I can't help you on getting it done, but I saw a Lexus concept car at the Houston Auto Show this weekend and they did the same thing, really cool!
Old Apr 5, 2004 | 09:45 PM
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
Transmission: 700R4 + Shift Kit
Axle/Gears: Auburn Posi; Richmond 3:73 Gears
TPIROC runs led's for headlights/parking lamps/sidemarkers PM him.
Old Apr 6, 2004 | 09:47 AM
tpiroc's Avatar
Car: GM & Jaguar
Engine: Various
Transmission: Various
Axle/Gears: Various
I don't have any pics close up of my LED headlight installation but can explain. For all the exterior bulbs I just got LED replacements to fit OEM locations. However before that I used RadioShack white LED's with a resistor and made my own sockets. For the headlights, I simply soldered lead wires off of the LED, insulated them, cut a notch in the H4 bulb, and insterted the LED with the H4 bulb. I bent the anode + cathode to keep the LED away from the bulb. I tried a couple different ways, but they light up best when tucked into the lamp glove so it reflects outward. It looks sweet when it's "dim" or "dusk" out. Just post any questions, and zNucleaRz, I'll get some info on my headlights to you later today, I gotta get to class
Old Apr 6, 2004 | 11:07 AM
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
Not meaning to hi-jack the thread but let’s see if I have this right. I guess you drilled a hole below the actual H4 bulb on that ring that runs around it and mounted a blue led bulb? Then wired it to something I was thinking about wiring mine to the parking lamps should be a good place. Is this right?
Old Apr 6, 2004 | 11:51 AM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
check e-bay they have tons of em for great prices, figuring out the specs of the led's you need is always interesting tho there is so much to choose from
Frozer!!!
Jan 19, 2024 04:55 PM
355tpipickup
Alternative Port EFI Intakes
Aug 29, 2015 10:47 PM
Dialed_In
Aug 20, 2015 01:45 PM
Omega
Aug 10, 2015 12:46 PM
