82 T-top repair
Car: 1982 Z28 Indy Pace Car
Engine: 305 LU5
82 T-top repair
I have an 82 with T-tops. The black polycarbonate channel that covers the edge of the T-top glass needs repair (cracked/broken). I've noticed that 86 and later cars don't have the channel around the T-top glass. Is the channel necessary to prevent leaks? If so, where to I find the replacement parts. (GM says the parts are discontinued).
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Hmm. Since I doubt that GM changed the sheetmetal, you should look into the possibilities of replacing the black divider piece between the tops with one from a newer model, and likewise replacing the gaskets to one from a newer style. This should allow you to use the newer style t-tops if the sheetmetal is the same.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
The IROC Homepage
Thirdgen89GTA
Nov 26, 2015 11:04 PM
