carbon fiber hood
Old Apr 28, 2004 | 08:48 AM
  #51
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
Engine: Dart Little M Twin Turbo
I like the cf design posted above... What I was thinking of was to make one similar to the C5R, and duct the radiator airflow out the top of the hood. Is this something similar to the Viper duct, or more of a forward facing duct for intake air?
Old Apr 28, 2004 | 12:35 PM
  #52
devianb's Avatar
CF is not only lighter than glass but stronger and can stand a little more abuse. Even though I have quite a bit of black trim on my car, id have no problem painting over cf.
Old Apr 28, 2004 | 01:07 PM
  #53
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
no.
it has the POTENTIAL to be lighter and stronger then glass.
however, when hand laminated like in thoes hoods or any hood someone would make for our cars, they weigh the same as glass, are only as strong as glass and can take no more abuse then glass.
this is the point that never comes across.
its only when its surrounded by high pressure air and heated with the proper resins that its actually stronger... its stronger because its dense from the compression.
you can do the same to fiberglass too
the weight savings only occurs when you do the same strength technique as above, but design it to use less material to take advantage of the strength.
unless you intend to make a $5000 + CF hood thats as thick as two sheets of paper, you arnt getting any more weight savings.
spend $5000+ on a CF hood thats as thick as the others, and you'll have one you can stand on and jump, but do you NEED that strength?
Old Dec 16, 2011 | 10:29 PM
  #54
AussieIROC66's Avatar
Car: NissanGTS-T, Nissan350z, 89IROC
Engine: 350ci
Transmission: TH700 4 speed automatic
Axle/Gears: 2.77
Re: carbon fiber hood
Another dead CF thread with no real info...
Old Dec 16, 2011 | 10:42 PM
  #55
Engine: 350ci
Axle/Gears: 2.77
TRANSLATION from www.grace-co.co.jp/car_hood_top1/hood_main1.html about there Carbon Fibre Hoods,...useing altvistatranslate
For the lightening and handling improvement 3rd CAMARO, the normal hood is required inevitability of light weight conversion by any means. With the after market there is also various commodities, but it was e.g., there are no any where agreement goes in regard to form and quality. This hood even precision functional surface form, developed and merchandised with prejudice and. Installing the small-sized outlet into the large-sized outlet and both sides in center. The exhaust heat effect from the duct is effective to [kamaro] of heat feeling. The leak in the roof from the duct, there is no worry in the engine compartment depending upon minute positioning. The weight which becomes matter of concern the normal hood became weight below 15kg and half vis-a-vis 32kg. Because the finish has become carbon area, paint it is not with it is OK. Because the hood is designed to be 2 piece structures, even strength there is no problem. There is no with either circuit travelling by this corporation demonstration car, either times when it pumps and in regard to efficiency it has become the commodity which is completed. You can install with volt/bolt on, but at that time you use original hood latch. The hood pin (difference to sell) please be sure to install for safety. Price including tax \ 147,000
Old Dec 16, 2011 | 10:52 PM
  #56
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
Aussie, you bumped a 7 yr old thread just to say another thread is dead?
Old Dec 16, 2011 | 11:16 PM
  #57
Engine: 350ci
Axle/Gears: 2.77
Your handle suits you. Is this not allowed?
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
