Best paint cleaner
Car: 1994 Trans Am
Engine: 5.7L LT1
Transmission: 6-speed
Best paint cleaner
Whats the best cleaner i can get. I used Turtle Wax Restorative polish to clean up my IROC's faded and stained paint. Only the hood won't clean up. It shines real nice but the stains are still there. The stains look like they were caused by some kind of liquid spill. The finish is damage but the paint is speckled. Does anyone know what i should use to remove those stains. I don't want to go for a repaint.
'88 IROC 305 TPI
Gutted airboxes
160 degree T-stat
Advanced base TPS voltage
Relocated IAT sensor
Momo steering wheel
Ram-air setup coming soon
'88 IROC 305 TPI
Gutted airboxes
160 degree T-stat
Momo steering wheel
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
A buffer with a fine compund, followed by a NATURAL wax, or just a polish.
I would use 3M Microfinish compound on a buffer wheel.
Sounds like it could be from tree sap or acid rain.????
Working on:
'84 Z28 LG4 305
Added dual elec fans.
145 MPH IROC Speedo
Building 430 HP 350
using primarily GMPP parts.
Block is in shop!
Working on:
'84 Z28 LG4 305
145 MPH IROC Speedo
Building 430 HP 350
Block is in shop!
malco rejuvenator.
good product, cleans up oxidation, stains and scuff marks real nice. i use the stuff where i work almost daily.
77 Nova, eibach 2" drop springs, 327ci, 14.5 @ 77mph,
www.slonova.com
www.slonova.com
Car: 1996 Trans Am WS6
Zaino clay or Clay magic
then 3M FIne cut rubbing compound
then your favorite wax or Zaino
Or, if its really bad, clay it then wet sand with 2000 grit and water/soap lube, then 3M compound and wax.
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
