what upholstery cleaner do you use??
Old Apr 30, 2004 | 10:41 PM
llvll4l2c91350's Avatar
i need some feedback because i need to clean the carpet and seats and stuff but am not sure what to go with. there's different products out there but i'd like to hear what some of you guys use. i used to use tuff stuff which seemed to work fine but i'd like to know if there's something that works better. thanks.
Old Apr 30, 2004 | 11:45 PM
jay92,85,79's Avatar
Car: 85z28,
Hey this might not sound good or right but i use this stuff called hot shot its carpet cleaner.This guy i use to work with hit this guy on a bike.And than gave him a ride to the doc.There was blood all over the back seat.We try a bunch of differnt stuff(at the time weworked at a hardware store)Man that stuff took it right out.
Old May 2, 2004 | 12:46 AM
uhhhhhhhhhhhhh i guess only 2 people in this whole board clean their interior. go figure
Old May 2, 2004 | 12:58 AM
TA's Avatar
TA
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
I bought a carpet steam cleaner that has an upholstery tool. My brother bought a late model cheap because the upholstery was all stained, and we used the carpet spot remover and the upholstery tool on the steam cleaner, and the interior now looks new. You might check and see if a rental carpet cleaner has an upholstery attachment? You will be amazed what it will suck out of your carpets and upholstery.
Good luck
Troy
So Cal
Old May 2, 2004 | 04:43 AM
89V6FBIRD's Avatar
Car: 1999 Pontiac Trans Am
Engine: LS1 - 346 ci
Oxy-clean, that stuff does WONDERS. I had stains at least 2 or 3 years old come out w/ a solution of the stuff. And its pretty cheap for the amount you get. I think its like $6 for a 5 lb tub or so? And all you need is a little scoop for your solution.
Old May 2, 2004 | 01:47 PM
Hg's Avatar
Hg
Car: '87 Z
Engine: 355 in the works
I agree with TA, a steam cleaner, the ones like a vacuum, with the accessory tool, and then some kind of spot remover. That's the best I've used... makes the car smell fresh too. It pulls some nasty stuff out of the carpet...
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
RedLeader289
May 28, 2019 01:47 PM
zman1969
Oct 1, 2015 11:09 AM
dusterbd
Sep 29, 2015 08:40 AM
Marc Brown
Sep 28, 2015 01:40 PM
