need some help picking out my boyd rodder 5s
Old May 3, 2004 | 10:42 PM
easySPEEDcamaro's Avatar
Car: 1992 Camaro Z28 Anniversary Edition
Transmission: Borg Warner 5-Speed
well finally time to make that sig pic of mine a reality.
i will be ordering the rims by the end of the week.
i need some help. i am not sure what size to get. i'm pretty set on the 18s, but i'd like some help for the backspacing and stuff...
here the rims:
here are the prices:
Set of 4 wheels...
17" $1295
18" $1595
19" $1995
20" $2295
22" $2995
24" $4750
i'm looking at the 18s or 19s...
here are the backspacings available:
Wheel Sizes
17x7, 17x8, 17x10
18x7, 18x8, 18x9, 18x10
19x8
20x8.5, 20x10
22x10
24x10
so, what do you guys think... also i need some help finding tires... what size tires with what size rims... appreciate the help thanks.
Old May 3, 2004 | 11:05 PM
Mr. IROC-Z's Avatar
Car: 1990 IROC-Z (De-Badged-Carbon Hood)
Engine: Superram 383
Transmission: T-56 w/upgraded Viper Internals
Axle/Gears: 3.73 18x8 and 18x11 irocs
Hmmm...I always thought that was the way your car looked presently...good photochop!
I would say go with 18x8 fronts and 18x10 rears.
245/40/18 fronts and 295/35/18 rear.
Can't wait to see what she looks like!
Keep us updated on the CF hood also...I am jealous
Tommy
Old May 3, 2004 | 11:48 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
18x9 all around
Old May 4, 2004 | 12:12 AM
IROCFAST's Avatar
18x10's out back with 5.75" or 5.85" backspacing with a 295/35r18 out back and an 17x8 with a 245/45r17 up front or 18x8 with a 245/40r18 both with 4" backspacing. Should look really good!
Old May 4, 2004 | 12:14 AM
1992rs/ss's Avatar
Car: 92 RS, 05 GTO (sold), 10 TL AWD
Engine: 383 HSR w/DSC1
Axle/Gears: Strange S60/3.73
do they make a left and right side wheel? they in opposite direction in your sig. I usually don't care for wheels with "leaned" spokes cause they look backwards on one side.
Old May 4, 2004 | 12:39 AM
CrazyHawaiian's Avatar
Car: too many ...
I did mine 18x8 front w/ 4.5" backspacing w/ 245/45/18 tire and 18x9.5 rear w/ 5.5" backspacing w/ 275/35/18 tire. If I did it again I would probably go for 18x10 rear, 18x9 front and re-measure the backspacing so they are all the way to the edge of the fender lip (current setup is inset a bit when compared to the lip of the fenders)
Old May 4, 2004 | 12:47 AM
123jon321's Avatar
Car: '86 iroc
Engine: lb9 305
my votes for 18s. With 19s you would have to run a decent sized sidewall as not to bend the rim and big rims plus anything besides low profile tires equals what I think someone on here referred to as the "hotwheels" effect. IMO 18s are as big a can be done on thirdgens while still looking good.
Old May 4, 2004 | 07:42 AM
DURTYBIRD's Avatar
Car: '99 HO Z28 / '03 Trailblazer
Ditto. Its supposed to be expensive for wheel manufacturers to make two different wheels for one style - so they usually just have the same pattern on both sides. I'm not sure whethers boyds are like this or not.
Old May 4, 2004 | 09:36 AM
FLYNLOW92rs's Avatar
I would vote for the 19x8 size, as that's what i have on my car and i'm happy with them.....
If you are going for 18's, then get soem 18x9 or 18x10 in the rear and 18x8 in the front...
nothing above a 40 series tire...
Old May 4, 2004 | 11:04 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
id say go with the 18's unless you have another daily driver. 19's might look great (ive never seen them personally) but you run too much of a high risk. 18x8 w/245/40/18 FRONT 18x10 w/295/35/18
as far as backspacing i would like to know the exact numbers needed as well for the above dimensions because thats what im looking into gettting and just need to know the correct backspacing/offset.
i think they would look killer on your car.
Old May 4, 2004 | 11:54 AM
Graboid's Avatar
tire size
a 295 on the 10inch wide boyd rim looks like ***. I have 275 and even that looks not perfect. I would suggest a 265 or 255 although i know no one will agree with me
Old May 4, 2004 | 12:03 PM
90firebird's Avatar
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
24x10's all around!!!
naw, jk... i say 18x10's in the back and something slightly narrower in the front... not too knowledgeable about backspacing; but i'm sure crazyhawaiian's help will be valuable since he already has had experience with boyd's...
Old Jun 10, 2004 | 04:11 PM
1986z28's Avatar
Car: 86 z28, 87 IROC, 88 sc, 93 z28
Engine: LG4, LB9, LO3, LT1
Transmission: 700r4, T5, 700r4, 4L60
Axle/Gears: 3.73, 3.45, 2.73, 3.42
I have contacted them on this before and they make the wheels in a left set and a rights set so they all face the same way
Old Jun 10, 2004 | 04:46 PM
nolanr0413's Avatar
Car: Trans am
i ordered 18x8 in the front with 4.5 bs and 18x9.5 in the rear with 5.5 . I dont know if id go for 19s on a car thats driven very much . I dont know if you might bend a rim .
Old Jun 10, 2004 | 04:51 PM
Kandied91z's Avatar
i think it all depends on where you want your wheels to sit. i myself like them in the stock location. i'm extremely happy with my 18x8 front 4.75 bs and 18x10 rear 6.75 bs but i had to cut a bit of the bumpstop off in the rear. going with this bs though allowed me to keep the wheels in the stock location which makes lowering and everything else so much easier. if you want to push it to the edge go with 9's in the front but that's more then enough.
here is how the 10's looked with 5.75 bs. this was alright but i couldn't lower the car much and when i stepped up to a wider tire like my 295/35 dr it rub quite a bit, especially with a passenger in the car. so i moved them in to 6.75 which worked alot better. also the larger lip with the 5.75 was alot easier to bend as i bent both hoops very quickly with the 4 1/4" lip.
Old Jun 10, 2004 | 04:53 PM
Kandied91z's Avatar
here they are rehooped with 6.75 bs and only a little more then 3 1/4" lip. not as deep of a dish as i'd like but i don't have to worry about any of the hassles i had. things that i wish i knew before hand.
Old Jun 10, 2004 | 04:54 PM
Quick6's Avatar
Car: 1991 Camaro Z28
Engine: L98 5.7 V8 TPI
How about 19s in the front and 20s in the back.
Old Jun 10, 2004 | 04:55 PM
Kandied91z's Avatar
here is how my fronts sit with a 18x8 at 4.75 bs. if i were running 9's i would be roughly 1/2-3/4" further towards the fender (sticking out) and i would not be able to run a coilover or in my case an air strut so for me not only is an 8" perfect for my driving preference but is the only way to work with my suspension.
Old Jun 10, 2004 | 04:57 PM
Now we are talking.....:hail:
Old Jun 10, 2004 | 04:58 PM
Kandied91z's Avatar
i do like the staggered look though on our cars. it would look alot like this when rolling which is nice.
Image removed.. you know the rules.
Old Jun 10, 2004 | 05:33 PM
DURTYBIRD's Avatar
Based on your observations, would it be possible to increase the backspace just a little to compensate for part/all of the additional 'frontspace' ?
Old Jun 10, 2004 | 07:05 PM
Kandied91z's Avatar
as in...?
increase backspacing so that you have less space up front?
not sure i'm following. if you run stock suspension yes you could move the wheel inward even more or decrease the backspacing. if you move the backspacing up more or move the wheel out you could but then you run the risk of lowering problems as well as rubbing and whatnot.
what is it your asking?
Old Jun 10, 2004 | 09:22 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
kandied....i absolutly think the way your car sits is perfect. so when i get new rims i should get 18x8 w/4.75 BS and a 245/45/18 tire for the front. then a 18x10 w/6.75 BS and 3 1/4 lip and 295/35/18 out back?
what all was involved in cutting the bumpstop was that due to the rims or you lowering the car more?
Graboid - why do you say that a 295 on a 10 in boyd looks so bad?
Old Jun 10, 2004 | 10:12 PM
DURTYBIRD's Avatar
as in...?
If I'm not mistaken (it wouldn't be the first time I was ), increasing the backspace of the wheel will push the 'hoop' of the wheel further into the wheelwell while leaving the face of the wheel in the same place. This will also increase the backspacing (i.e. 5" backspacing to 6" pushes the wheel further inward). It also increases the offset of the wheel (i.e. 0mm to +24mm, etc).
Nevertheless, I think you did answer my question. So with your coil-overs, you don't have as much room behind the wheel as a stock suspension, right?
Old Jun 10, 2004 | 11:51 PM
Kandied91z's Avatar
correct, because of the coilovers. particularly the large ones i was running with a 3" dia it was tight. with the new air ride suspension the strut bags are almost 4.25" dia which is just about as close as you would want to cut it.
everyones different, just stating what worked for me....
CamarosRUS you pretty much have it right, had to cut the bumpstops in order for the rim to roll. had one slight area that sort of stuck out about 3 1/2x2 1/2" in area that had to be hammered in roughly 1/4". it didn't keep the wheel from rolling but clearance was so tight that it was needed to give it that little bit of room for suspension shift left to right. it was very easy and quick to do....as much as i was against it i'm so much more happy doing so unlike when i had the wheels sticking out.
Old Jun 11, 2004 | 12:07 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
thanks for the reply. maybe its just me but wheel stick out is not a fashion statement on cars looks like well, misfitted wheels IMHO
Old Jun 11, 2004 | 12:10 AM
Kandied91z's Avatar
i agree, there is no mistaken that i have wide tires out back which is nice but at the same time they aren't directly in your face like they were with the above first setup. however if you don't want to cut anything on the car you really need a smaller backspacing like that 5.75 but then you get the larger dish which makes street driving rough and it sticks out.
Old Jun 11, 2004 | 11:42 AM
Car: too many ...
Well if anyone wants to know what the 18x8 w/ 4.5" BS front and 18x9.5 with 5.5" BS rear looks like from the side of the car (to show how it sits in relation to the fenders), here are some shots:
Front High - Close
Front Low - Close
Rear High - Close
Rear Low - Far
Old Jun 11, 2004 | 01:10 PM
nolanr0413's Avatar
Car: Trans am
crazy , thats looks aweosme, i cant wait to get my rims now. Im glad i went with the same bs front to rear as you . Lemme ask you this, is thier room for a larger tire, maybe a 285 or 295 to fit back there.
Old Jun 11, 2004 | 04:49 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
well i dont mind cutting if it is just hte bumpstop......wouldnt mind at all for a perfect fit!!!
Old Jun 11, 2004 | 06:24 PM
Kandied91z's Avatar
crazy can you get a pic directly behind...i'd like to see the relation with 5.5
Old Jun 12, 2004 | 02:08 AM
Graboid's Avatar
camarosRUS:
because a 10 inch (25,4cm) wide rim is the home for a 255 - 275 tire. For a 295 you need a 11 inch rim.
Old Jun 12, 2004 | 09:58 AM
Kandied91z's Avatar
285/35/18 is actually as close to stock as you can get for my vehicle on a 10" wide. 295 is the smallest width in an 18" dr and works just fine.
couldn't even imagine stretching a 255 on a 10" unless you had a tall profile.
http://www.miata.net/garage/tirecalc.html
Old Jun 13, 2004 | 03:43 AM
Graboid's Avatar
There's no stretching involved in putting a 255mm wide tire on a 254mm wide rim...........
Old Jun 13, 2004 | 02:15 PM
Kandied91z's Avatar
what sidewall would you go with....35? you would have a more rounded tire. less protection on the edges.
Old Jun 13, 2004 | 02:22 PM
nolanr0413's Avatar
Car: Trans am
i too would like to see a rear shot or what a 5.5 inch bs looks like with a 9.5 inch rim.
Old Jun 13, 2004 | 04:02 PM
Graboid's Avatar
255/40 18
Old Jun 13, 2004 | 05:32 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
well im learning quite a bit here keep posting
Old Jun 14, 2004 | 02:04 AM
Kandied91z's Avatar
255/40/18 on a 10" wide wheel. i'm assuming this is what your running. any closeups of the side profile. i'd like to compare.
Old Jun 14, 2004 | 06:49 AM
Graboid's Avatar
I'm running 275/40 now. But when i need new tires, i will change to 255/40. They have the same diameter like the 225/45 i have in front. If you like to see a close up of the 275's, feel free to ask
Old Jun 14, 2004 | 03:43 PM
Kandied91z's Avatar
throw them up...if you could get a slight angle off the rear that would be good. always nice to compare sizes. too bad tolerances weren't closer between brands though.
Old Feb 9, 2005 | 06:09 PM
  #42
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
Bringing back for some more info.
Kandied, you wouldn't happen to have the pictures that you posted originally showing the various angles, do you? Also, do you have any pictures of where you modified the bump stops? I could not find those anywhere I searched. Thanks for any help, this thread has already provided plenty of info.
RedLeader289
May 28, 2019 01:47 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
jaridjohn
Oct 5, 2015 07:01 AM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
92projectcamaro
Sep 29, 2015 07:07 PM
