First Attempt at Polishing Aluminum!!
Old May 4, 2004 | 01:18 AM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
Started Polishing new TPI I just purchased. I've never tried polishing Aluminum before so I figured I'd start with the least important piece....the thermastat housing. Turned out better than I had planned!! All was done by hand starting with 80 grit to remove some of the deep nicks in the aluminum and worked my way up to 2000 grit, finishing with Mothers aluminum polish. I used my Craftsman dremel tool with a carbide bit to remove the casting marks and the 2 protruding bumps on the front of the housing just above the front bolt hole. Those of you who have TPI know which ones I'm refering too. What do you guys think of my work?? Next piece to get polished is the Plenum!!
Old May 4, 2004 | 01:21 AM
Project_1986_TA's Avatar
Car: 1986 Trans Am WS6
Engine: Mild 350 TPI
Looks sweet, how long did it take you?
Old May 4, 2004 | 01:24 AM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
LOL took me a long time. Only because this piece was pretty banged up, was considering buying a new one to start with but figured I'd try to get this one looking good and it came out pretty good...took a lot of sanding with 80 grit. I'll post pics of the plenum when I get that done.
** Thanks to those who helped **
84customZ28
JLP
Kandied91Z
Old May 4, 2004 | 05:16 AM
aziroc's Avatar
Car: 86 IROC-Z
Engine: 406
overall i saw it looks wonderful, but u can still see the lines in it.. either got ape**** with 2000 grit for a long time, or get some of that tripoli stuff * i think white???* and the little buffing pad. it will take the lines out.
Old May 4, 2004 | 06:59 AM
ss85tadude's Avatar
Car: 85 Trans Am
Transmission: 700-R4
Just to let you know you only have to go 400 grit wet.
Good job on it though
Old May 4, 2004 | 09:17 AM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
yeah I know about the lines. After I get all the other pieces up to this point I'll purchase a buffing pad and some white rouge to give it a mirror finish.
Old May 4, 2004 | 11:08 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
i just started polishing my LT1 tips yesterday and i just now have all the black off of them. im glad it turned out so well for you that gives me a little more comfort!! after i get this done (Practice) im gonna tackle my TPI system and alternator etc.
great job!
Old May 4, 2004 | 12:09 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
You should get yourself a nice buffing wheel and some white rouge, it would make that sucker look like chrome!
Looks good though!
Linson
Oct 24, 2025 02:00 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
