Help with T-top seal replacement
Old Sep 20, 2000 | 08:07 PM
Iroc_Z28's Avatar
i was just wondering how much it would cost to have my seals changed and where would i even take it too...i have tried several body shops in my area and they wont do it any help is appericated
Old Sep 21, 2000 | 10:06 AM
Nightcruzer's Avatar
Car: Trans Am
Several companies sell the T-top weather striping replacements. Try Classic Industries, Next Generation or Ames Performance. It will run you about $200 for everything you need. Then check the tech articles on this web site for the instructions on how to actually do it yourself. I did it and the only advice I have is don't be cheap with the adhesive. Put too much and wipe the excess. You will not be dissapointed.
Old Sep 21, 2000 | 01:26 PM
john91gta's Avatar
even more important than the adhesive, is the sealant. Put as much of it on as you can. I changed my weatherstripping once and put very little on, and my car leaked. I had to redo the entire process (which meant buying another weatherstripping kit). The second time I did it I used a whole tube of bathroom silicone sealant. I put a large amount under the metal t-top spacer and then put more between the t-top spacer and the actual weatherstripping. Now my car is super water tight with no leaks. Remember, you can't really put too much on.....
Old Sep 22, 2000 | 10:37 AM
Neil's Avatar
Car: '87+'02 Z28
Engine: 454 LSX
Transmission: T-56, Viper output shaft
Axle/Gears: Strage 12-bolt 3.73:1
I just re-sealed my t-tops, and I strongly suggest that you do not use silicone! It works great for a while, but will eventually lose a seal. I have done this job several times (on different camaro's) and what I use is a 3M Multipurpose Automotive Seam & Joint Sealer (dries to a rubbery texture and it's a bright white in color)- use this to attach the T-bar/plate to the chassy(make sure you remove this, clean it up and/or replace it if it's rusty, water can work its way under this and soak into the headliner, so don't skip this step! Also use 3M Weatherstrip Adhesive (it comes in a black and yellow color - I would get the black) to apply the weather stripping. Where the weatherstripping attaches to the body with screws (the 4 corners) make sure that these areas have a good tight seal! My car for example has a huge gap in these areas, and I had to use a harder sealant 3M Seam & Joint sealer #08505-(I think this is the correct number, I will let you know if it's a diff. #) to build up this area. A word of advice, be patient, apply thin coats of this joint sealer and let it dry, then apply again.If you want, e-mail me: nleotcs@hotmail.com
gta90
Sep 15, 2015 04:00 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
Penultimo
Camaros Wanted
Aug 20, 2015 08:42 PM
qz6lwp
Aug 20, 2015 08:10 PM
Leggman1
Aug 6, 2015 04:15 AM
