New paint
Old Sep 10, 2000 | 09:42 PM
89project's Avatar
New paint
My 89 Iroc is Metallic Blue. I am wanting to get it repainted. Sanded to the metal, a no sh** NEW paint job. What is the normal price for something like this. Actually never had a car repainted, just don't wanted to get ripped off.
Old Sep 10, 2000 | 10:01 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
I have a friend that works in a reputable body shop, and they would get lik $2500 + for a real paint job. Far from a Macco job, in quality and price. I'm going to do my own car, but maybe slide one of that shop's painters a couple hundred to do the spraying for me.
This is not a "Couple weekend" project!
Working on:
'84 Z28 LG4 305
Added dual elec fans.
145 MPH IROC Speedo
Building 430 HP 350
using primarily GMPP parts.
Block is in shop!
Old Sep 11, 2000 | 07:27 AM
Chuck Everly's Avatar
I agree with JP84Z430HP. A good paint job will cost $2000 to $3000. I am in the middle of painting my IROC and have $1300 just in materials. That is using a 3 stage red paint but it still cost a lot to use good material.
88 IROC convertible
So slow it is timed with a sundial
[This message has been edited by Chuck Everly (edited September 11, 2000).]
Old Sep 11, 2000 | 07:40 AM
Matt98SS's Avatar
if you are willing to do the prep work yourself (sanding, taping, etc) then you will save LOTS of $.
Old Sep 11, 2000 | 09:25 AM
Ben87GTA's Avatar
Im just about to start sanding down my car and prime it... anyone have any good info on what kind of primer to use, what grit paper, and just general things about prep work? I am trying to make this paint job as affordable as possible thanks,
ben
87 5.7 gta - ASCD Ram Air II hood, all the ghetto mods, cam, rockers, chip, exhaust, functional ram air, blah blah, all that stuff. best et: 13.96 @ 99.21mph r/t .601
Old Sep 11, 2000 | 12:40 PM
Hank Brote's Avatar
I just had mine done this spring. Total bill was $6K. That is taking it down to the metal and bringing back up..... That was with new weather stripping all around, new graphics etc. Cost a few dollars but it was worth it to me. http://personal.atl.bellsouth.net/at...brote/main.htm
Hank
87'IROC Z28
Old Sep 11, 2000 | 03:19 PM
daniel dekay's Avatar
hey ben, use 80 grit for the sanding. go to metal cuz u will get the best results of everything is removed. i used 120 for a while then switched to 80 and it went 2 times faster. havent gotta clue about what brand primer, except that you should spray it on using an air compressor, not the spray can.
Old Sep 11, 2000 | 08:23 PM
Ben87GTA's Avatar
thanks dan, I was wondering if I would have to buy a compressor; now I know I have to... This is going to be a big project.. but at least my friggin bumper finally came in. took pontiac 2.5 weeks to get it when they said it would take 3 days. Not bad considering I got a Gen. GM bumper for 179 bucks (god, i love hookups )
-Ben
Old Sep 11, 2000 | 09:50 PM
JP84Z430HP's Avatar
Car: 84 Z28
Make sure that you hand sand that hood with a "long board" sanding block. If not, you risk having your hood look rippled. This goes for any 'glass hood.
For primer, I'd go with the same brand as the paint you plan to get. They usually work better as a system. I always reccomend PPG and DuPont paint products, PPG first. I may get DuPont, because the parts store our shop get parts from carries it!
I also wouldn't skimp on the sandpaper either. A quality paper will pay for itself! I would use 80 grit on a DA sander, then primer it and work up to finer paper. 400 grit or better on a DA, or 320 or so by hand. I've been using Carborundum abrasives paper, and seem s to be doing well.
On a final note, Cleanliness is godliness! You may think you have it clean, but you can get it cleaner! It just takes one dust spec to ruin the whole car for you!
Working on:
'84 Z28 LG4 305
145 MPH IROC Speedo
Building 430 HP 350
Block is in shop!
[This message has been edited by JP84Z430HP (edited September 11, 2000).]
Old Sep 22, 2000 | 01:43 PM
G92Joe's Avatar
If cost is $2-3,000 for new paint job,how much more would it cost to go with a color change (considering all visable and hidden original paint is changed to new color)?
Hotrodboba400
Dec 10, 2019 07:07 PM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
TheExaminer
Sep 6, 2015 11:40 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
