harwood hoods
Old Sep 13, 2000 | 09:40 AM
hookin88formula's Avatar
harwood hoods
i have a 1988 formula and i am getting ready to paint it this winter. i would like to knwo if there is a harwood hoods site. which of the harwood hoods come with the vents in the cowl? i am looking ot get a 4" cowl hood. thanks.
1988 firebird formula350tpi msd 6al box blaster 3 coil accel 8.8 wires flowmaster cat back pro shift light a pillar gauge pod and water temp and air/fuel ratio gauges b&m mega console shifter, march underdrive pullies, tpis airfoil
Old Sep 13, 2000 | 10:18 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Harwood doesn't have a website, and their cowl hoods are vented at the windshield at the back of the cowl, not on the sides.
I'd consider other options though. Myself along with many others that I've talked to are not happy with their Harwood. I also know others that are, but it seems that percentage wise harwood has issues.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Sep 13, 2000 | 11:54 AM
admrlam's Avatar
Im with Jim on this one, i have a harwood on my car, and it doesnt fit as well as i had hoped for it to. I would replace it immediately, but the money a 19 year old has isnt enough to be that picky and choosy. But definetely, if you dont have one yet, look around. Classic industries sells one, but im not sure who makes it for them. Its worth looking in to though.
1988 Formula, 305TPI, 700r4(for now), headers, stage 2 PROM, modded MAF, cat back, no catalytics, cowl hood, centerline champ 500 rims, KOBEL predator ground effects kit, Trans AM tailights, dash pouch, 92 shift console w/indicator, white face gauges, accented red trim, 12 speaker stereo, 4 amps, tint, T tops... icq 44373460 AIM:admrlam
see it at www.geocities.com/admrlam/bird.html
Old Sep 13, 2000 | 01:23 PM
LPE420SC's Avatar
The Harwood I have doesn't fit worth a ****. And, they are not ready to just "bolt on" as the catalog suggest. It took several hours of sanding and an hour of "notching" the hood around the headlights. It sucked, and the fit still blows.
Old Sep 13, 2000 | 01:42 PM
Chuck Everly's Avatar
Well I was one of the lucky ones that got a good hood. I have seen some of hoods that were not prepped right and did fit poor.
As the post above mentioned the hood is NOT ready to bolt on. There is a 3/4" lip all the way around the hood that needs to be trimmed off in the front and back of the hood.
EDIT: I am not saying that you all did a poor job of prepping. I know at least Jim’s hood was really wavy and I suspect the others had a poor hood also.
88 IROC convertible
So slow it is timed with a sundial
[This message has been edited by Chuck Everly (edited September 13, 2000).]
Old Sep 13, 2000 | 08:09 PM
ok so what kindof of hood should i look into? i like the way the cowl hood looks but i also like the ss hood is there a way for me to make a forced induction hood out of that or do they seel one? what are some sites to look into?
Old Sep 14, 2000 | 08:12 AM
www.americansportscar.com has the SS style hoods. Have you ever seen one in person? I like the way the underside of the hood if finished but I really dislike the way the back of the cowl is done.
I think there is one other site called www.usbody.com that has hoods for our cars.
88 IROC convertible
Old Sep 15, 2000 | 04:33 PM
BOWTIROC's Avatar
From: Coulterville, IL...Currently on Beale AFB, CA
I bought an Unlimited Products 2.25 cowl for my car, when I got it the scoop measures 3.5 and the fit was pretty damn good. For $219 you can get the one that pins in front and bolts on in back, and for $295 you can get the one that bolts on. It only weighs 22lbs. Shipping was about $50. One and only complaint, the gel coat that it comes with could be thicker.
Old Sep 17, 2000 | 01:08 AM
does unlimited products have a web site? who else has web sites to hood let me know have the flow and neeed to spend it.
Old Sep 17, 2000 | 02:20 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
www.up22.com
Old Sep 23, 2000 | 02:23 AM
Zant69's Avatar
yeah, unlimited (up22) is good... also.. I have a harwood site (as bad as it looks) I don't know how to put links on here so I'll just type it out> http://www.martelbros.com/harwood/12.htm also cervini's has a couple> http://www.cervinis.com/index.html
Everything I know I learned by messing it up at least once.
Old Sep 23, 2000 | 02:25 AM
Zant69's Avatar
Hey, maybe I DO know how to put up links! oh joyyy! hehehe
Old Sep 23, 2000 | 07:39 PM
Kevin S's Avatar
Several months ago CC_HotRod sent me some info about a place called Class Glass.
They offered the same hoods for $150 less then what Jegs or Summit offered them for.
But they hand make their own.They are made on order.
If we make enough noise CC_HotRod may post the number.I can't find the magazine with the phone# on it or I would post it.but I will look for it.
Kevin S
10.9 @ 62.87 (1/8 mile)
89 RS 2.8(bored .030)
B&M shift Improver
B&M Mega Shifter
Perma Cool trans cooler
Accel Wires,
Ignition module,
Super coil
Streetrunner chip(for now)
Flowmaster
1.52 Roller rockers
Things You Will Never Hear a Man Say....
Damn, too bad this car isn't a four cylinder.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
