Repainting small area with base/clear
Old Sep 26, 2000 | 08:34 AM
89IROCkid's Avatar
I've done enamel patch work before, but never worked with base/clear coats. The rear bumper on the IROC was hit hile parked, and some paint has come off a small section about 4 x 2 inches. IS there any special to apply the base/clear coat?? With enamel i just sanded, painted the color and waxed it later. Do apply the base coat, then right away the clear, or do i compound the base before applying the clear etc.
Thanks guys
Sat "IROCkid" Bimrah
1989 IROC-Z 5.0 L / 5 spd
Old Sep 26, 2000 | 09:53 AM
Bill91Z
Guest
Posts: n/a
I believe Chris wrote a killer article on this in the tech article section, check it out.
-Bill
-=ICON Motorsports=-
Boston Chapter
91Z28, (in progress) 3.8L, TE63-1 turbo, MSD50lb injectors, Hemco upper, ported TTA heads, 62MM TB, Red's XP fuel pump, 3.73s, vigilante (stall to be determined)
Old Sep 26, 2000 | 10:53 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I'm not a fan of blending because it's not as durable as a regular coat of paint, but unfortunately it's done often because it's cheaper than painting a whole panel and color matching tends to be more forgiving.
Anyway, wetsand a large area with 600-800 grit paper until it's not shiny anymore. Don't overdo it because factory clearcoat isn't amazingly thick. Paint the color over the affected area (duh) then go 50% to 100% farther with the clear. After it dries, wetsand the whole un-masked area with 1500 until you can't feel any overspray or that sort of crap, then buff the whole panel.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
350 IROC-Z
Camaros Wanted
Dec 18, 2015 03:58 PM
Jorlain
Oct 8, 2015 01:57 AM
64goatman
Sep 9, 2015 01:09 PM
BOOT77
Sep 5, 2015 03:55 PM
machinist21
Sep 5, 2015 03:03 PM
