Eibach prokit or sport line
Car: 85 TA
Engine: 305 tpi
Transmission: 700
I'm gonna get some eibachs but i'm afraid the drop will make me scrape the bumper everytime im on an incline. Is anyone having this problem?
Car: 91 Z28
Transmission: built 700R4
I found a good price for the pro kit and an adjustable panhard bar on Ebay. I just ordered them last night. here is the link to the thread I started.
link
link
um , go with the sportlines, i have them and im glad i got them . I didnt want to go with the pro kit that it wouldnt be enought of a drop. The sportlines look really good and give it the stance that the car shoulda had from the factory.
Car: 85 TA
Engine: 305 tpi
Transmission: 700
worn out springs on a high mileage car will sit as they are with a pro-kit. if you want the car to look lowered go with sportlines but accept that you have to learn how to drive. i hardly scrape anything with the car sitting on the ground but you need to learn how to drive that way.
Car: 85 TA
Engine: 305 tpi
Transmission: 700
Car: 1990 firebird
Engine: 3.1 v6
damn i really like the way your car sits nolanr0413, but im scared that i will be hitting my wheelwell, do your tires hit yours? how does the car drive, id hate to mess up the way it handles, i only want improvement on handling not so much on looks , id hate to have my car ride rougher then what it does
my wheels dont hit yet. but i did order some 9.5 inch rims for the rear, so i may have a rubbing issue, but ill see, The reason the rear looks lifted is that I have a chrysler rear end and the axle tubes are bigger than the stock ones, which raised the points up a little bit. Im gonna cut some of the coil off when i get the other rims and see how it looks. I like how it handles now. It seems to be better. When you change the springs your gonna need an adjustable panhard bar and lower control arm relocators and u should bugdet some new shocks and struts.
Car: 85 TA
Engine: 305 tpi
Transmission: 700
if you have factory wheels at spec you would have some serious issues hitting fenders with them.
I guess all i want to know what size wheels are the biggest i can get without having any rubbing or hitting issues cause i'd like some 17/18s don't know how thick though.
If you are already scraping, lowering won't help
You drive a lowered car differently then you drive a stock height car, if you don't make the change in driving behavior, there will be issues.....
Car: 94 Corvette
Engine: LT-1
Transmission: Freakin Automatic---For Now
To get up your driveway with out the scrape, you have to go at an angle until all 4 tires are on the incline, trust me. I lowered the front with BellTech's (2 full inches) and the rear with sportlines for a 93 (about 1.75 inches) and I never scrape anything except the air dam. I had tire rub issues at first, but after a set of shocks & struts and an alignment, I hevent rubbed once. If you don't want to seriously adjust your driving, don't lower it. It's a pain in the ***, and I get the finger alot, for railroad tracks, dips, speed bumps, driveways, etc... Here's mine.
By the way, the rear in this pic is before the rear springs. I'll get pics of how it is now next time I wash it.
GTA-SPD, i think you have the lowest thirdgen trans am , sorry gta i have ever seen , Everytime i see that pic i feel for you . But i wish i had a set of those lowering spindles ,b/c then id love it just as much as yours.
with the proper back spacing 20" wheels are the largest that can be fit on our cars with the proper 26" tall dia. tire. as far as width depending on what size tire and rim you go 8" wide up front and 9.5-10" wide out back is about as wide as you would want to go without rubbing or having to modify things..........again this is if you have the right offset/backspacing.
what i was saying is if you are running the stock wheels and stock correct backspacing you should not come close to hitting the fenders at all, if you are coming close you have a problem. my wheels are at stock edge spec and i can set the car on the ground before they rub anything.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
...i can set the car on the ground before they rub anything.
specificly, pics of your front struts.
Car: 91 Camaro Vert
few days....
few days....
Car: 94 Corvette
Engine: LT-1
When I first lowered it I had all kinds of issues but now, after driving it for almost 2 years like that, it is second nature to me. I look pretty retarded slowing down to a crawl at dips in my Z71 Pickup, but by the time I remember I don't have to, I'm almost stopped anyway.
I put a new air dam on it every year because it does drag a lot (it don't drag hard, just often) and if it breaks off, overheating quickly follows. Also so I don't have a ghetto looking piece of black plastic dangling from the front of my car. I found a guy on eBay that sells NEW GM air dams for $30, so I keep a couple on hand.I was reading in a mag about 2 months ago and think I may have found a company that has the spindles, the catch is you have to buy their brake kit too. Stainless Steel Brakes lists a brake kit for our cars built on a lowereing spindle, but I can't get a straight answer out of them for sure. I am on the lookout for another set of these spindles so I have a spare set, just in case.
Car: 1990 firebird
Engine: 3.1 v6
you want to see low im going to see if i take a pic of a vert camaro i see around my house, i dont even know how he can drive around the city in that thing, half the time i see him in east new york, where the streets look like a war took place there
Car: 85 TA
Engine: 305 tpi
Transmission: 700
Originally posted by therckid
i have sportlines in my floor irght now that i got for $20, you guys paid way too darn much.
Car: 85 TA
Engine: 305 tpi
Transmission: 700
Originally posted by MrDude_1
after we have pics, am i allowed to call up QA1 and ask if we can buy struts NOW?
to be honest i don't see that happening for quite some time....when i know i'll let others know.
Guest
Posts: n/a
i have sportlines
i have an odd question or comment
what would cause a car to be 1 inch lower on the entire passenger side of the car?
my entire passenger side of the car sits about .75 inches lower and causes my passenger rear wheel to scrap bad.
what the hell could be the problem with that? and as far as i can see.. the springs look to be seated correctly.
in reality that's the car though...throw some lt headers on the car and you'll have to do it at stock height. no matter what height your car is at you should take extra caution with our cars to go in on angles as it's better.
Car: 1990 firebird
Engine: 3.1 v6
Originally posted by KiLLJ0Y
i have sportlines
i have sportlines
Car: Camaro
Engine: 355c.i.
Transmission: th350
my boy's brother sold them to me. They were on his 91Z
Car: Camaro
Engine: 355c.i.
Transmission: th350
i'm gonna get them looking like new. you wont even be able to tell they are used.
Car: 1986 Trans Am
Engine: 305 LB9 TPI
Transmission: 700-R4
well if they search around they might find used ones a lot cheaper, you never know.
If i sound stupid i appoligize i just got off a 6 hour phone convo with thewoman, so i might be a little stupid right now.
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
It doesnt matter if your gonna be able to make them look like new. That doesnt change the fact that they are used. Supreme Member
Car: 02 ws-6
Engine: 5.7 liter
Transmission: t56
i have 17inch rims and dropped it with the pro-kit and i love the stance. I don't have any ground clearance issue . Heres a pic of my rims with stock springs
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
oh and about having hedders... i have hooker supercomp fulls and even with my crappy suspension i only bash em when i go over unreasonably tall speed bumps where even if i crawl over them my front end goes up over and bounces with the bad fronts struts and shocks....
Car: 1991 Camaro RS
Engine: 357cid
Originally posted by moreyes
like how? i know going up and down inclined garages scrapes the hell out of it no matter how slow i do it
83 Crossfire TA
Sep 8, 2015 12:06 PM
