FINALLY DONE (this time around) LOTS of pics inside!!!
Old Oct 21, 2004 | 07:18 PM
  #101
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
awsome
Old Oct 21, 2004 | 07:34 PM
  #102
nick418's Avatar
Engine: L98, Hemi 6.2
nice system!:hail:
Old Oct 22, 2004 | 09:16 AM
  #103
SweetRide45's Avatar
redraif: Out of the gun, there is typically a good amount of orange peel. I used 3 base coats and 4 clear coats. After sanding and all, I'm guessing around 2 1/2 to 3 clear coats left. I used a medium activator so it would flash in about 15 minutes or so. After all the coats are on, I left it for about 3-5 days to cure to the point where I could sand. Started out w/ 1000-1200 grit, then worked my way to 2000. You'd be surprised how fast 1000 cuts, so take it easy! After that, I used some compound on a foam pad, buffed it out, then did my glazing, and there she is
One note is, that if you don't use the right pressure out of the gun, it will do nothing but marbalize the paint, and it will be TERRIBLE. It should look very "wet" and "uniform" w/ "minimal" amount of peel when it's first applied. During the flashing and curring process, the peel will creep out, but no worries, it can be eliminated (As you can see) :rockon:
Good luck!
Old Oct 22, 2004 | 11:47 AM
  #104
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
SweetRide - can you post a link to the thread you mentioned above on your process? I checked all your posts and couldn't find it....
Sure would appreciate it!
Old Oct 22, 2004 | 12:24 PM
  #105
This pertains to a fiberglass hood, but the general information applies to the whole body:
Fiberglass, on it's own, is far from being "flat"...It takes lots of prep work (depending on the given quality) BEFORE you paint. If you havn't done body work before, it might take some time to understand.
I'd suggest to sand the gelcoat down w/ some 320...use a long block, and foam block around curves, etc. Then, lay some primer on there, and sand that down...give it a few coats...never be afraid of primer...it's your friend
Sand that down w/ 320 as well...if necessary, shoot it again...
Fill in any cracks/etc. w/ bondo and/or fiberglass, spot putty, etc...
Your trying to achieve a smooth look w/ the primer...to cover all area's, and especially to soak into your fillers, so it doesn't bleed through.
Next, use a different deeper color primer as your guide coat. This will show you any imperfections and high/low spots. Sand everywhere in a uniform fashion until all of your guide coat is gone, and your left w/ primer again.
After that, give it a few more coats of primer, sand that all down, now you should have a pretty solid foundation for paint.
Use some prep on there, then a tack cloth, and your ready for your color.
I put the heater on roughly 75-80 before I painted (I did it in the fall to keep down on dust and/or bugs. I put down 3 coats of base (black in my case). I let each coat "flash" (dry) for 15 minutes between coats. Then I layed down 4 coats of clear in the same fashion. After that, I waited a few days (as stated above) before I sanded the whole thing down w/ 1000. After that, I washed it clean and dried it completly to see the spots I missed. I switched to 2000 and did the whole thing again. You want to use a light directly in the location your wetsanding as to see the peel. It will show up as "dark" spots/lines as opposed to the flat "dull" parts that are sanded.
Don't stay in one spot too long while sanding. Constantly use long smooth back and forth motions w/ a long sanding block. Small speratic sanding will create lines and/or can damage the finish. After this process is done, I used a wool pad w/ my Dewalt 849 polisher and put some compound down. I got a majority of the big sanding scratches buffed out, then I switched to a "cutting" foam pad. This will start to produce a hazy "uniform" finish. After this was done, I put more compounds on and used a "buffing" foam pad. This will start to produce your final finish. You'll see the "glass" appear right before your eyes.
If, after you do all this, and you see some more spots that you missed, don't be afraid to hit it w/ some sand paper again. Just be sure to use a fine grit, preferably 1500-2000. It will take a few times to cut through your compounds before it will start to sand down any peel. Just remember though, don't sand TOO much, as, your always taking paint off, and once you go too far, it's too late.
The base coat is just to provide you w/ your color...once you have the same color everywhere, that's where the clear comes in. You'll be sanding THIS part of the paint, and never the base. Also, TOO much clear and/or base will make the paint have a tendancy to "Crack" and it will lose it's durability. I've found that the 3/4 combo works best for me.
If there's anything else you would like to know, let me know if I failed to state something. I pretty much covered the general idea's on the process. You don't need a "Spray Booth" to have an awesome finish. All you need is some good planning/make sure it's not raining out/and keep the dust/bugs to a minimum. I just tarped off the inside of the garage w/ some sheets, closed all the windows/etc. w/ two exhaust fans blowing outside, put the heat on to mid temp (75-80), put only an air filter at the gun side, and let 'er rip.
Good luck!!
Old May 3, 2006 | 03:07 AM
  #106
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Old post, but your car is done well. Very nice.
Old May 3, 2006 | 01:22 PM
  #107
Thanks man! Wait til I post the pics of what's gonna be under the hood
I'm currently preppin' the bay, but soon enough
Old May 3, 2006 | 01:38 PM
  #108
Aquafied Iris's Avatar
Car: 1987 Pontiac Firebird
Engine: 2.8L V6
Transmission: 5 Speed Manual
Amazing finish. I had to look twice to at the sail panel pic.
Old May 3, 2006 | 02:11 PM
  #109
TheWesman's Avatar
Outstanding paint work.
With so much body work and paint prep, how come your driver door sags so much? Not trying to offend, I'm curious because I've kicked around shooting some paint like that, and might have the same issue. Did you just not replace the hinges? or is it a aftermarket door/skin issue?
TheWesman
Old May 3, 2006 | 02:20 PM
  #110
idk what you mean man. They are new hinges and there isn't any sag or play issue w/ either door
Old May 3, 2006 | 02:23 PM
  #111
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Axle/Gears: 3.42 Peg Leg
No idea wtf Wesman is talking about, your car looks fantastic!
Old May 3, 2006 | 02:44 PM
  #112
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
Safe to assume the engine has been meticulously maintained like the rest of the car?
What's it got?
Old May 3, 2006 | 02:47 PM
  #113
crazynights's Avatar
Car: 1982 Z-28
Engine: 383
Transmission: Turbo 350
Axle/Gears: Det. Posi, Superior Axles, 3:73 G
That has got to be the finest Birds I've ever seen!! You did an amazing job and am sure you are very proud!!!
Old May 3, 2006 | 03:04 PM
  #114
Thanks a lot guys! Here's a sneak peak of what she's gettin'...
Can u say 383
Old May 3, 2006 | 06:08 PM
  #115
TheWesman's Avatar
You got the paint to a mirror finish (very impressive), if you look in/at the reflection, you can see a major break in the reflected image, at the door and B-pillar.
TheWesman
Yes it does look fantastic, I'd be proud to own it.
TheWesman
Old May 3, 2006 | 06:18 PM
  #116
nosaint's Avatar
Car: 1986 Trans Am
you had me right up until the neon.....
But then I'm old.....
Old May 3, 2006 | 07:39 PM
  #117
JBert's Avatar
Car: Looking
I had never seen this therad until now. All I have to say, is that you're car and Steve's black Firebird (305SVS or whatever) are my two favorite!
Great job!
Old May 3, 2006 | 08:28 PM
  #118
92RS(real slow)'s Avatar
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
nice formula, but whats up with the firebird spoiler
Old May 4, 2006 | 12:28 AM
  #119
Knyghtmare's Avatar
Car: 1991 Camaro
Engine: 2000 LS1
Transmission: 4L60E SS3600
Very sharp man. Looks good.
Old May 4, 2006 | 12:47 AM
  #120
Thanks again..
Wesman, ever think it's the angle and/or camera picture that's throwin' it off? It's as straight as an arrow...
92RS, I prefer the Base spoiler over the Formy molded rubber (or the fiberglass one)...
Old May 6, 2006 | 02:31 PM
  #121
mettalicirocz's Avatar
Car: 1986 camaro, 1993 nissan altima(winter beater, 1992 mustang (summer daily driver)
Engine: 350tpi
Transmission: 700r4 with shift kit
very very nice, just tuck those tail pipes up a bit but good work
Old May 6, 2006 | 06:38 PM
  #122
Matthew91-Z28's Avatar
Car: 1991 Z28 Convertible
Axle/Gears: 3.23 with Eaton posi
what lights did you use underneathe the car. That looks cool
Old May 6, 2006 | 09:39 PM
  #123
Mettalicirocz - I have a whole new exhaust goin' in w/ the new engine...don't worry about those tail pipes
Mat - Streetglow Gold Series
Old May 19, 2006 | 12:32 PM
  #124
ontarioiroc's Avatar
Car: 90 IROC-Z
where did you get your valve covers. I love the black and aluminum colors. Looks really good!
Old May 19, 2006 | 04:12 PM
  #125
LT4 Composites w/ MBA Trim
Thanks!
Old May 19, 2006 | 11:31 PM
  #126
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
Yea that car looks great...the paint is just amazing.
Opinons are like a**holes but heres mine, along with the mud flaps loose the windshield banner and don't ever turn on those neons again
Old May 19, 2006 | 11:34 PM
  #127
lol, mudflaps stay, banner stays...and neon's are gonna be on
Old May 20, 2006 | 12:38 AM
  #128
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
I figured so...I just wish I could have half the car that is.
I'm not sure of you posted this but how many hours you have into that paint (not counting spraying the car)?
Old May 20, 2006 | 12:40 AM
  #129
Cam-aro's Avatar
Car: '91 Z28
Engine: L98 H/C/I - 400whp
Axle/Gears: Moser 12-Bolt(4:30 w/spool)
Nice job rocking the underglow. People don't give it respect on Fbodies, but it looks great. You really should of went with something like Red. Your color is WAY to common on Ricers. Here's my old '91 with Red Streetglow Underglow:
Old May 21, 2006 | 12:18 AM
  #130
I'm not sure on how many hours I have in the body work...but it's getting repainted this winter
And the color IS common on my neon, but r!cers couldn't even step UP to me...so, it doesn't matter
Old Jul 25, 2006 | 08:46 PM
  #131
camaroracer016's Avatar
Car: 88 Camaro
Engine: 5.3
Transmission: TH350
anyway you can re-post the pics, i cant see em
Old Jul 25, 2006 | 09:01 PM
  #132
compuwiz1937's Avatar
Car: 2012 Corvette
Engine: LS3
Transmission: TR6060
Yeah, the pics are broken.
Old Jul 25, 2006 | 10:08 PM
  #133
I know...host went down...I'll get some newer pics up once I'm at the next stage...almost
Old Jul 26, 2006 | 01:14 AM
  #134
Julie Bergman's Avatar
Car: 91 Formula WS6
Transmission: five speed
Kewl, I have '91 Formula resto-mod project...hoping to get some ideas! Right now the 383 and T-56 are being dropped in. The Medium Maui Blue Metallic is peeling off, like the color though and am going to get it repainted that color. Car will look stock from the exterior.
Old Jul 26, 2006 | 09:03 AM
  #135
vernw's Avatar
I like that stock looking exterior myself, Julie. The only giveaways to mine are the dual tips on the hooker catback and the "6.2 LITER" replacement stickers on the power bulge....
Old Jul 26, 2006 | 09:49 AM
  #136
Badass_recaro's Avatar
Car: 1982 Recaro T/A
Engine: 305 w/Carter carb.
Transmission: TH-350
Axle/Gears: stock
Am I the only one who does'nt se the pics?
Old Jul 26, 2006 | 09:54 AM
  #137
unklechuckles19's Avatar
Car: 1987 Z-28
Engine: 355
Axle/Gears: 10 Bolt/3.23 peg leg :(
I cant see them either, dont feel bad Badass_recaro
Old Jul 26, 2006 | 10:02 AM
  #138
lol, man, this was an old @$$ post...I'm surprised someone brought it back...I'm gonna have to host these pics again to show what's up, lol
Old Jul 26, 2006 | 11:42 AM
  #139
Car: 91 Formula WS6
Heh! Right on Vern, I have been checking out your project too, it is in my line of thinking.
Old Jul 26, 2006 | 11:46 AM
  #140
89rocket's Avatar
Car: 1989 RS
Engine: 2putt8
wow, nice *** 3rd gen
Old Jul 26, 2006 | 11:58 AM
  #141
vernw's Avatar
Thanks, Julie. I've been thinking about some AFR heads and possibly a miniram or LT1/4 intake, essentially converting it to an LT4 stroker and maybe even adding the SEFI '95 or so LT harness and ECM. Never enough time or money for everything though...
Old Jul 26, 2006 | 01:13 PM
  #142
Car: 91 Formula WS6
LOL! Indeed Vern. I happened to luck into a great deal on a low mile stroker ('91 TPI block) built by the local speed shop for a fellow CMC racer some years back. He put about 1k race miles on it and yanked it out, has been in his garage ever since. He made me a great deal on the motor, it even came with a TPIs big mouth intake! I'm going with Superram plenum and runners, LPE 219 cam, 1-3/4 SLP headers and Jeff Creech tune. The suspension has been completely redone also with the exception of the springs (I think they are fine). Can't wait to take it out for a spin!
Old Jul 26, 2006 | 01:42 PM
  #143
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
i cant see the pics.
Old Jul 26, 2006 | 03:54 PM
  #144
vernw's Avatar
I imagine - Good Luck with it!!!!
Frozer!!!
Jan 19, 2024 04:55 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
backtothe80s
Sep 5, 2015 12:39 AM
mustangman65_79
Aug 11, 2015 03:17 PM
Kaweh
Aug 9, 2015 02:54 PM
