from 16"-18" rims
Old Jul 14, 2004 | 08:21 AM
vortech305's Avatar
from 16"-18" rims
I guess most of you thought a pic was here, but not just yet. What i forgot to realize is that wont my rear ratio change, since my original tire size 245/50ZR16 is going to 295/40ZR18. I originally have 3.42 out back, but will going from 50 to 40 help retain the 3.42 ratio or do i have to go lower?
Old Jul 14, 2004 | 08:33 AM
Graboid's Avatar
285/35 or 245/40 if you want to be as close as possible to the stock diameter
Old Jul 14, 2004 | 08:44 AM
vortech305's Avatar
I had no idea that the width of the tire would affect the ratio. I thought it was only the diameter of the rim and tire.
Old Jul 14, 2004 | 09:14 AM
camaro-mayhem's Avatar
Car: Camaro
Engine: 355c.i.
Transmission: th350
Re: from 16"-18" rims
youd be going from 25.6 inches around to 27.3, so your speedo would definetely be off (with the 295/40's)
a 285/35/18 would would you at 26.9inches so it wouldnt be noticeable.
a 295/35/18 would be 26.1 and would probably be bearable too.
if you go with a 35 series tire then make sure youre careful if you drive it on the streets
Old Jul 14, 2004 | 09:22 AM
jovial86's Avatar
Car: 1986 Pontiac Firebird
Engine: 1991 305 TBI
Transmission: Th700-R4
Re: Re: from 16"-18" rims
I know this is a stupid question, and its because of the narrow sidewall, but why? What are the negative side effects of running a narrow wall?
Old Jul 14, 2004 | 10:24 AM
iroc2nv's Avatar
Car: 1987 iroc-z custom
Engine: 355 tuned port
Transmission: 5spd baby, only way to go
Axle/Gears: 3.45
i went from the stock size of 245/50/16 all round to 265/35/18 on back and 225/40/18 up front..
i dont notice my speedometer any different..
the reason with a smaller sidewall you have to take more care is because usually when you have a small side wall the actual width of the tire isnt that wide and wont take most of the impact..
example
245/50/16 is for instance this wide /......................./
and this is the side wall _
............................... _
while my 265/35/18 is this wide /.............................../
and this for a side wall _
..............................._
as you can see (hopefully ) that you have more padding with more of a sidewall to protect you rim..
also find attatched my front rim and tire.. 225/40/18 maybe can show you there stock tire (the 245/50/16)
iroc2nv
Old Jul 14, 2004 | 11:30 PM
Car: Camaro
Engine: 355c.i.
Transmission: th350
narrow sidewall makes it easier to mess up the tire or damage the rim. especially if you go with a rim that has a deep dish.
Old Jul 15, 2004 | 02:03 AM
Xlr8torZ28's Avatar
Car: 1991 Z28 & 1992 Z28
Engine: LB9 & L98
Transmission: T56 & T56
Axle/Gears: 4.10s & 3.23s
http://www.juric.org/mopar/tools/tirecalc.php
try this tool... it rocks
Old Jul 15, 2004 | 02:14 AM
CrazyHawaiian's Avatar
Car: too many ...
I recommend re-inforced sidewalls if you go 35 series or lower. Like these guys said, if the sidewall is too small and not re-inforced its possible for the rim to be damaged if you hit a pothole. I'm running re-inforced 275/35/18 tires in the rear (245/40/18 front) and my few run-ins with potholes have resulted in no damage. Hope this helps.
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
kitt23
Exterior Parts for Sale
Nov 28, 2015 06:26 PM
dbrochard
Oct 10, 2015 01:03 PM
dbrochard
Oct 10, 2015 01:02 PM
