MESSAGE FOR KARPS TA
Old Oct 9, 2000 | 07:26 AM
hookin88formula's Avatar
I WAS WONDERING WHAT KINDOF HOOD U HAVE. I HAVE A 1988 FORMULA350 AND IT LOOKS GREAT ON YOUR CAR SHOULD LOOK BOUT AS GOOD BUT NOT QUITE SINCE U HAVE THE GROUND EFFEXTS TO SET YOURS OFF. IS IT FUNCTIONAL? DID U NOTICE THE CAR RAN COOLER IF IT IS? ALSO I LIKE THE WING THAT IS AN A&A WING ISNT? DID U GET THAT THROUGH JEGS? HOW MUCH DID U SPEND ON THE WING AND THE HOOD? THANKS
1988 firebird formula350tpi msd 6al box blaster 3 coil accel 8.8 wires flowmaster cat back pro shift light a pillar gauge pod and water temp and air/fuel ratio gauges b&m mega console shifter, march underdrive pullies, tpis airfoil
best 1/4 mile run of 14.44@ 96.53
Old Oct 9, 2000 | 08:36 AM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
The hood is an American Sports Car Ram Air hood from www.americansportscar.com. I think it cost me @$450. The spoiler is from A&A. The hood is setup for TPI cars that have the air box on the paseenger side. I'm carbureted and just didn't have the time or energy to make it functional. Come winter I'm going to fabricate a carb pan to seal to the hood.
Quality of the hood is very good. Needed some work but no more than most fiberglass hoods from what I've heard. The spoiler on the other hand is pretty dissapointing. It's made out of a type of foam that paints weird.My body man spent alot of time on the spoiler and it still looks like the paint is bubbled in spots. Not too noticable to most but it bothers me.
Old Oct 9, 2000 | 04:16 PM
thanks a ton you car looks good to me and i would be very proud of it so does all the materials come with the hood to make it funtional? y car is tpi so that interests me alot
Old Oct 9, 2000 | 05:41 PM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
The hood is molded so that the air gets routed to the side. There is just a hole cut for the air to come thru. So it's pretty much up to you to figure out how to hook it up. I'm not even sure how much cold air gets there even.
To be honest I bought the hood first for looks, and with the thinking that I could rig something up if need be.
Quite a few guys have the hood on here, maybe one of them might know more on TPI applications.
kkirch15
Interior Parts Wanted
Oct 15, 2015 02:21 PM
Linson
Oct 1, 2015 09:50 PM
3.8TransAM
Sep 27, 2015 08:37 PM
6998poncho
Sep 25, 2015 02:56 PM
