Best method for sanding wheels and using Mothers Alum polish?
Old Aug 27, 2004 | 12:08 AM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Right now I'm wet sanding formula wheels with 150 grit and 220. All I have to use is mothers aluminium polish to make it shine. I'd like the closest thing to a mirror finish with buying buffing compounds, or tools to do this. I remember reading if you press lightly with Mothers, it will shine better.
So far my plan is 150 wet, 220 wet, 320 wet, 400 wet, and mothers.
Old Aug 27, 2004 | 02:13 AM
steves86TA's Avatar
Car: 2008 silverado
Engine: 5.3
if you want it really shiny, go to about 800 or 1000 grit then mothers
Old Aug 27, 2004 | 03:37 PM
confucius101's Avatar
here we go again
just read the wheel polishing post at the top of this fourm
i've just finished use 180 dry 130 wet the 400 wet paint then bee's wax method myself and found 5 customer's within a week
Old Aug 27, 2004 | 09:18 PM
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
The sticky leads me to use buffing compounds, so that's why I started the thread.
Old Aug 28, 2004 | 04:21 PM
undr cnstrn92RS's Avatar
Car: 92 camaro rs
Engine: 305 tbi
Transmission: 7000r4
i have always had the best luck using 4 aught (0000) steel wool. it works better than sandpaper i think to removed the discoloring and baked on mud and dirt, plus its easyier than switching sandpaper.
Old Aug 28, 2004 | 07:33 PM
grngryoutmyway's Avatar
Car: 92 Z28
Axle/Gears: 3.73 10 bolt
whats wrong with buffing compounds.... its really the only way to make them mirror finish if you sand any higher than 400 you'll start getting a haze to the wheel. I got emory, tripoli, white rouge and some buffing wheels at home depot for like $30 so its not expensive.... and you could probably take them back when your done if you really want.
Old Aug 28, 2004 | 11:39 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
I used 80, 100, 120, 180, 220, 320, 600, 1000, 1500, 2000, (on my plenum) then used a high speed buffer with mothers polish...and it looks like a mirror...no regrets..
Everyone has their own techniques though....and that was mine..
Hotrodboba400
Dec 10, 2019 07:07 PM
TheExaminer
Sep 6, 2015 11:40 PM
SG91camaro
Sep 5, 2015 10:27 PM
WickedBowtie
Exterior Parts Wanted
Sep 5, 2015 04:58 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
