engine paint ?'s
Old Oct 29, 2004 | 11:39 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
engine paint ?'s
well i had my valve covers blasted and primed, have to paint them, and the plenum, and the runners... problem is, i don't really like the colors of "engine enamels" i see, so wondered how well some of that other stuff would hold up. ?
didn't really want to do this in the first place, but the runners got messed up by someone else, and covers had corrosion on them, so might as well make it all match.
KAM
Old Oct 29, 2004 | 11:46 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
Re: engine paint ?'s
KAM
what other stuff do you mean ????
Old Oct 30, 2004 | 01:53 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
gotta get a high heat enamel, pretty much gotta use the stuff you can find for engines
Old Oct 30, 2004 | 07:28 AM
Car: '91 Z28
Axle/Gears: 323's
Re: Re: engine paint ?'s
i meant the other paints, like metalcast and whut-not. i don't want to paint and have to remove everything to repaint again...
KAM
Old Oct 30, 2004 | 08:58 AM
heavy_chevy29's Avatar
Car: 84 camaro Z28
Engine: 434sbc
Axle/Gears: moser 9" with 411 posi
if you put down epoxy primer first you can paint them with any automotive paint like dupont,PPG, standox, sikkens(sp),etc. then you can use what ever color you want
Old Oct 31, 2004 | 12:28 PM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
The Metalkast will work, it has a high-heat tolerance. Probably couldnt use it on the block or heads, but it works great on the runners and valve covers.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
