Harwood leaking into cabin.
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I have a Harwood cowl hood. The one that looks like the 90-92 Z-28 with a 2 inch cowl. I have found that whenever I drive the car in the rain it leaks water down into the passenger side floor board, at least a cup full. Has anyone else had this problem?
Car: 1984 Pontiac Firebird
Engine: 2.5L Iron Duke 4 cylinder
Transmission: 5 speed manual
I have the same problem. Look in your engine bay...below the blower motor for your interior HVAC. Down underneath it you may find a load of crud that rotted your firewall. I have this problem and every time it rains, there is a pool of water in the floorboard.
If that's not it, then check your heater core.
-bill
-bill
Car: 1991 Z28 Vert
It is not coolant. It is not oil. It is water, only there when it rains. The heater core works fine. I lose no coolant whatso ever. I have been able to follow down where it is leaking. I will look to see if there is a "rotted" hole in the firewall.
Heater box Gasket? Describe this more please.
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
Car: 1991 Z28 Vert
Originally posted by SLP IROC-Z
it seals the heater box to the firewall so things like water dont get into the heatr box and then into u car
Re: Harwood leaking into cabin.
Car: 2002 SS
Engine: Ls1
Axle/Gears: 3:42 posi
LOL i highly doubt just because you put a hood on ur car ..that now inside the car your seeing water...:lala:
i dont have any problems
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Car: 91 Camaro RS
Engine: TBI
Yea i have a 4" harwood and have no probs. I am considering putting the factory hood seal in the back onto the hood somehow to seal teh motor compartment since i get watter puddles sitting right under the hood. I dont wanna drill holes in the hood to attach the seal though
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
I drille holes in my harwood to use the factory seal..it was easy
