87 ground affects on a 84 (camaro) anyone do it?
Old Dec 7, 2004 | 03:25 PM
PhantomFE3's Avatar
Car: 1984 Z28
Transmission: TCI Streetfighter TH350
Axle/Gears: 4th gen 3.42
has anyone done this? take ground affects from a newer camaro and put it on there early 3rd gen? if so, do you have pictures? and if noone hasnt, do you think it would look good?
Old Dec 7, 2004 | 03:45 PM
qytum's Avatar
Car: 92 Formula
Engine: 5.0L TBI
Axle/Gears: 3.73 posi
Your going to have to change the front and back bumper. Then if your car didnt have the early ground effect, you have to drill holes in the doors, fenders, and rear quarters. Also gonna need to fab up a bracket to hold on the rocker panel. The bracket on the 85 and up cars are welded to the body.
Definately doable if you can get a good deal on the whole set. I did it on my 84 but dont have any install pics.
Old Dec 7, 2004 | 03:57 PM
PhantomFE3's Avatar
Car: 1984 Z28
so ill have to replace the front bumper? i shouldve been more specific i am just talking about the front ground affect. if i get a front ground affect i cant just unbolt the stock one and bolt on the one from an 87? im ok with drilling holes and stuff in them to attach it to the bumper cover but it seems like alot of work for just swapping front ground affects?
Old Dec 7, 2004 | 04:02 PM
85_ZED28's Avatar
Car: '85 Z28
you do have to replace the bumpers
Old Dec 7, 2004 | 04:26 PM
meridius's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7 TPI (Now HSR)
Transmission: 700R4 by Probuilt
Axle/Gears: 3:27 9 Bolt Posi W/ Discs
yeah the contour of the front bumper is slightly different from the 82-84 style to the 85-90 style so it wont line up correctly.
Old Dec 7, 2004 | 07:15 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
You dont necessarily need to change your FRONT bumper.If you want to keep that early look.Personally i like the look of the 82-84Z Fr.bumpers,but i like the later style GFX & Rr bumper.I took the later style Fr. GFX & cut it where it lines up with the fender/bumper seam.I then cut my 84 Fr. GFX in the same spot.I then spread out the 84 piece so it would have the same taper as the later style.You might see the two sections in this pic.
Old Dec 7, 2004 | 07:20 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
O.K.Heres a somewhat better pic,but its dark out already....
Old Dec 7, 2004 | 07:26 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Other side,if it matters
Old Dec 7, 2004 | 11:44 PM
PhantomFE3's Avatar
Car: 1984 Z28
so its only the sides that dont match up? right in front of the front wheels? and all i would have to do is cut both GFX at that seam and find a way to hold them together? sounds easy enough, i think im up for it, thanks!
Old Dec 8, 2004 | 01:20 AM
RaceReadyRS's Avatar
Car: '89 Camaro RS
Engine: 305 TBI
I got this pic from chevycamaro.com, if memory serves me correct, it's an '84 with a '92 ground effects kit. Looks sweeeeet to me
Attached Thumbnails 87 ground affects on a 84 (camaro) anyone do it?-d92c.jpg
Old Dec 8, 2004 | 01:35 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
Try contacting xpndbl3 on these boards. When I swapped my 85-90 ground effects for the 91-92's, he took my old stuff for his 84 Z.
Old Dec 8, 2004 | 05:38 PM
BOTLFED's Avatar
Car didn't originally come with ground effects.. I added this stuff off of an 82..
Then this last summer I upgraded to 85 Z28 stuff..
Cheers,
Old Dec 8, 2004 | 07:13 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
I should clarify this a little more.The sides DONT match up comestically(the 84 is shorter than the later by about 1.5 inches),but mechcanically they differ only by an extra bolt at the end in front of the wheel.The 84 uses a plastic rivet while the later type use a bolt.Also the two are NOT held together.They are completely seperate items.I can remove the bumper & the stock 84 GFX bolted to the bumper with the end piece still on the fender.The 82-84 Front GFX are completely different in the way they bolt to the bumper,but not as much in they way they bolt on the fender.If you want to keep that early look.Youll have to find a way to do this mod(i only did this for cosmetic reasons,so the end of the GFX matches the rocker GFX in its width(taller than the 84).Anyway,As far as the rest of the GFX stuff goes.It should bolt right on with NO mods.including both bumpers (if your wanting to update looks).
Frozer!!!
Jan 19, 2024 04:55 PM
Thomas
Exterior Parts for Sale
21
Oct 7, 2015 05:33 PM
Thomas
Oct 3, 2015 05:34 PM
Jae992
Aug 27, 2015 09:07 AM
GVMV
Aug 16, 2015 07:08 PM
