Other Options for A/C Delete Boxes???
Old Jan 10, 2005 | 10:02 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
are there any other GM models that use the same standard heater box as the 82-92 fbodies??
i know a lot of people want to do the ac delete and the camaro/firebird boxes are sort of hard to find.
Old Jan 10, 2005 | 10:07 AM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
Nope, no other modles have a swappable box. But... from what I have heard, you can take a box out of a S-10 and bolt it up, and with a little fab work, make it futional for the f-body. Someone on here posted pics of it but not sure how well it works.
Old Jan 10, 2005 | 10:18 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
ahh i see well it was worth a shot. i guess ill just have to go over spend for a fbody one
now i need to work on a spacer so i dont have to try to find a new fan too!
Old Jan 10, 2005 | 10:40 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
the fans are interchangable from one non-ac to another. i put one in my car from an old 70 something fullsized pickup truck.
Old Jan 10, 2005 | 12:58 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
well thanks 66nova. i know it would be tough to make a spacer but having the ability ot grab any fab from a GM non a/c car makes it easy.
Old Jan 10, 2005 | 02:54 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
actually it`s not that hard to make a spacer.i did it to my 88 .i got some cheap hard foam sheets from the arts and crafts section at wal-mart,only 33 cents a piece it took me i think about 6 sheets to make a proper spacer .it holds up pretty well,but the one thing i did have to get was a new blower wheel from autozone ,it was only ten bucks so it`s a pretty cheap and easy swap.i also got lucky and found a non- a/c box from the junk yard for 15 bucks check it out inthe pic.
Attached Thumbnails Other Options for A/C Delete Boxes???-2b.jpg
Old Jan 10, 2005 | 03:20 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
wow $15 is a nice find. none of my junkyards have any non a/c cars!!! but one thing i did dig up was using some thick double sided adhesive foam to use. one member used the heavy duty closed cell foam that was 1" think and double sided sticky and huge said its held up for almost a year now.
Terrell351
Jun 13, 2021 01:13 PM
greenyone
Aug 29, 2015 11:08 AM
BlackphantomZ28
Aug 21, 2015 07:12 PM
actionj
Carburetors
Aug 16, 2015 09:51 AM
BikeFarm
Aug 11, 2015 11:35 PM
