Need help ASAP! on getting these rims off my rear end????????????????????????!!!!! :(
Old Mar 26, 2005 | 12:32 AM
  #51
rolling-robert's Avatar
Car: z-28 x2
Engine: 355ci and 305ci
Transmission: th350 and th350
be sure to keep new bearings in stock, because they will die after all that kicking and beating
Old Mar 26, 2005 | 08:01 AM
  #52
CrazyHawaiian's Avatar
Car: too many ...
I change wheels quite often (either to drift or clean up the wheel), so I dont ever seem to have this problem. But this is some good info to know if I ever do run into this problem. I did have a lugnut strip once, ended up having to drill out the stud. That sucked.
Old Mar 26, 2005 | 08:23 AM
  #53
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
Drill out the stud? Why didn't you just hammer it out the back?
Old Mar 26, 2005 | 08:47 AM
  #54
Car: too many ...
It was stripped on the pass side front wheel (16x8 IROC) with the rim still on the car.
Old Mar 26, 2005 | 10:38 AM
  #55
NEEDforSPEED's Avatar
funny thing is i still haven't got them off yet
Old Mar 26, 2005 | 10:39 AM
  #56
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
I think that in our friends time of need, this seriously requires holy intervention. I will say a prayer for you, anyone else with me.
Old Mar 26, 2005 | 10:54 AM
  #57
FirehawkSS's Avatar
Car: 87 Firebird,
Engine: lq4
Transmission: gto t56 (mn12)
Dude this is the lamest thing i think ive ever heard of. Is your time worth it? Just trash the wheel and buy a brand new one. Your time is much more valuable.
Here is an idea. Wrap a tow rope around the rim real good. Then connect the metal part to a car with a tow hitch. Leave the lug nuts on but leave enough room for the rim to break free. Then tell your friend in the other car to go... close your eyes and watch him yank the freak out of your wheel. It will pop loose for sure. Either that or it will tear your differential out. Have fun!
Old Mar 26, 2005 | 11:01 AM
  #58
AutoX86Z28's Avatar
Car: 86 Camaro
Engine: none
Transmission: none
Axle/Gears: GT4, 3:73s
snap on makes a great prying tool. the tool prys on the caliper and the inside of the wheel. i belive its called a crows foot. ive never had to use a big hammer, torch , or even penetrating oil. i just stick that tool on there and with some leverage the wheel pops right off. if you could borrow it from a shop or rent one, this would be the solution to getting your wheels off.
  #59
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
You need to get about a 6' long 4x4 and wack them off, by using wood it is less likely you will damage the rim/tires. Be sure to leave at least 1 lug nut on each rim to keep them from flying off the car. They don't have to be tight, just on at least 3 or 4 threads. As already mentioned this happens very often with aluminum wheels that have not been removed in a very long time. Rule of thumb to go along with all this. NEVER SEIZE....
Old Mar 26, 2005 | 11:19 AM
  #60
18inchboyds's Avatar
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
Axle/Gears: 4.10 gears
thats pretty lame if you havent gotten the rims off yet.
Old Mar 26, 2005 | 11:48 AM
  #61
really tho, i havent been trying, basicy there still on the axle but its drop out, , whats going to be real fun is when im done with the rear upgrageds, springs/shocks/LACs/RLBs/trackbar/brakes and all that good stuff, then hitting the front only to fid out i have to beat them to death to get them off
Old Mar 26, 2005 | 08:57 PM
  #62
IROC-Turbo's Avatar
Tryed tranny fluid??To me it works better than penetrating oil.
Old Mar 27, 2005 | 12:45 AM
  #63
Spdfrk1990's Avatar
Yeh now that the rear is out soak it in some nut buster or something similar for a week or 2.
Old Mar 27, 2005 | 01:24 AM
  #64
sounds like a good idea,
BTW happy b-day, im one day late
Old Mar 27, 2005 | 01:29 AM
  #65
Spdfrk1990's Avatar
Thanks I got happy bday emails from all the other boards im on but not TGO lol jp.
Old Mar 27, 2005 | 06:50 AM
  #66
406TPI's Avatar
Car: 1985 IROC-Z
Ahh..I see.
Old Mar 27, 2005 | 12:02 PM
  #67
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
a block of wood and a sledge wont loosen them? try jacking the car up, put the lug nuts on loose, then let the car down as fast as you can a few times and see if that helps.
Old Mar 28, 2005 | 10:51 PM
  #68
twysted87's Avatar
Car: 87 gta 89 ta
Engine: 5.0 5.7
Transmission: 700r4 x2
rent a thing called a porta power it's a hydralic cylinder you pump it like a grease gun . put it on the tire and the wide base against anything solid behind it. this will get them off and spray an entire can of wd40 into it, around the lugs alot in the center where the cap goes. i change forklift and heavy equipment tires for a living. i do that all the time. my nephews iroc was the same way. aluminum bonds to steel better than you would think , hope you get them off soon
Old Mar 28, 2005 | 10:52 PM
  #69
twysted87's Avatar
Car: 87 gta 89 ta
Engine: 5.0 5.7
or a bottle jack works to if you can get it in there
Old Apr 2, 2005 | 03:21 AM
  #70
firestorm's Avatar
Car: Firebird
Engine: LG4
They still holding on?
Old Apr 2, 2005 | 11:04 AM
  #71
digital_burnout's Avatar
Car: 91 camaro z28
Engine: 355
Transmission: 5 speed
Axle/Gears: 410
have u thought about asking it to "please come off"
Old Apr 3, 2005 | 03:37 PM
  #72
chesterfield's Avatar
Car: Pontiac
how about wrapping a chain around it, hook on a come along with the other end around a post or a tree or a '55 Chrysler and ratchet until the wheel comes off or the cable breaks.
Old Apr 3, 2005 | 08:53 PM
  #73
stiers's Avatar
They were stil l on last weekend when I was over. I think he gave up for now. I am gonna bring a 2x4 and a 30lbs sledge over next time I go up. They WILL come off.
Old Apr 4, 2005 | 10:47 PM
  #74
firestorm's Avatar
Car: Firebird
Engine: LG4
Yah, maybe you should use manners.
Old Apr 5, 2005 | 01:39 AM
  #75
89V6FBIRD's Avatar
Car: 1999 Pontiac Trans Am
Engine: LS1 - 346 ci
Ahahhaha... keep us posted!
Old Apr 5, 2005 | 02:18 AM
  #76
MikeDirntRulez's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI (L03)
Transmission: 700R4 (MD8)
Axle/Gears: 2.73 Open (GU2)
???? what the heck do you drive through?
Super glue?
Burning hot lava?
I've never even dreamed of a wheel sticking this bad.
Old May 21, 2005 | 09:22 PM
  #77
HAHAHAHAHA, omg i cant get these mother F-ers off!~
Old May 21, 2005 | 09:28 PM
  #78
iv tryed everything so far now, next step a pool of acit
Old May 21, 2005 | 11:54 PM
  #79
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Does anyone have the video of some fwd jap car that they can't get a nut off? It has a long pipe over a wrench with a guy standing on the pipe.
Old May 22, 2005 | 06:28 AM
  #80
ddn69's Avatar
Car: 92 caddy PIMP
Engine: 4.8
Transmission: i dunno
this is rediculous.
Old May 22, 2005 | 12:36 PM
  #81
JamesY's Avatar
Car: 86 Camaro
Engine: 2.8L MPFI
Transmission: 700-R4
Sounds to me like your not trying hard enough... maybe its just me though.
We use a 40lb sleder hammer at work to get stuck dualie rims off all the time, and yes they are literally stuck from being tightened on the inside and exposed to all the elments because of their design. My suggestion is put all the lug nuts back on, loosely lower the car so the wheel is off the ground, but not by much, maybe a finger and a half. Then go hit up your hardware store, find the biggest sledge hammer they have, goto the liquir store, buy a 24 pack, go home, lie down and get your angles right so you can lie there, run the sledge against your driveway or garage floor into the wheel, do that for 20 mins, drink a beer, do it again for 2 mns drink a beer, by the time ur case is half empty you should have it if you were hitting ti hard enough. Don't forget after every hit or every 2 hits in one spot, rotate 90 degrees and hit again.
Old May 22, 2005 | 01:22 PM
  #82
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
lol and after half a case you'll be tossing the sledge through the sheet metal..
I used to work at a tire store too.. and from the advice I've heard and from what you said you've tried, I can't believe they havn't come off.. I havn't seen a rim I couldn't get off yet.
Old May 22, 2005 | 01:38 PM
  #83
JamesY's Avatar
Car: 86 Camaro
Engine: 2.8L MPFI
Yah exactly, we've had some tough tires, as we are one of the only shops around here that does RVs, Dualies, Truck tires, eevrything just about, and we have never had more then 10 minutes of hittng to get the wheel off.
Old May 22, 2005 | 01:45 PM
  #84
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
So you pulled the lugnuts off, right? All five? And not the plastic lug covers, the actual lugnuts?
Old May 22, 2005 | 08:29 PM
  #85
sellmanb's Avatar
Car: '86 Berlinetta
This was stated before, but loosen all the lugnuts a couple threads, soak it in PB Blaster, then go in reverse to about 20MPH then just slam on the brakes FAST. Then go forward to about 20 MPH and SLAM on the brakes. Then jack it up, and give it a try again. If that doesnt help, keep the bolts a couple threads loose and back into a curb (within a reasonable speed obviously)
Old May 22, 2005 | 08:38 PM
  #86
JamesY's Avatar
Car: 86 Camaro
Engine: 2.8L MPFI
But if you loosen too far off as soon as that wheel breaks loose its going to snap a stud and then you will be fixing more ****.
Old May 22, 2005 | 08:40 PM
  #87
ah, what to do....
this is really sucking ***!
Attached Thumbnails Need help ASAP! on getting these rims off my rear end????????????????????????!!!!! :(-duas.jpg
Old May 22, 2005 | 09:00 PM
  #88
JamesY's Avatar
Car: 86 Camaro
Engine: 2.8L MPFI
You took the rear end off? No wonder it isnt working. You need the whole car attached so when you nail it with a hammer it actually stays put and forces the rim off.
When you just have the rear end off, the whole thing can move, therefor not using full force, which is why your wheel aint coming off.
Old May 22, 2005 | 09:02 PM
  #89
JamesY's Avatar
Car: 86 Camaro
Engine: 2.8L MPFI
BUt I have a solution
roll that out into the middle of the road, hook one wheel up to a buddies truck, hook the other up to another truck, then go SLOW, you dont wanna snap ****, once there is no play, just keep them crawling forward, eventually one will snap, then quickyl slam on the brakes as those lugnuts are still there, unless you take them off.
If you dont got 2 trucks, attach one side to a tree, the other to a truck, same method.
If you dont got any trucks, call your local tow truck and see if he can come give you a hand
Old May 22, 2005 | 09:07 PM
  #90
no lol, it was on till today.... i deside to say **** it and i cut off the LAC's
Old May 22, 2005 | 09:10 PM
  #91
JamesY's Avatar
Car: 86 Camaro
Engine: 2.8L MPFI
You give up to easy :P
Old May 22, 2005 | 09:11 PM
  #92
we did this already
Old May 22, 2005 | 09:12 PM
  #93
ROFLMAO..... look at the frist post date dude, now look at this one....
Old May 22, 2005 | 09:17 PM
  #94
JamesY's Avatar
Car: 86 Camaro
Engine: 2.8L MPFI
2 weeks ish, PIFT
haha yah I sense your frustration. I'll make yah a deal, you ship your rear end up here, I will take mine out and make sure the rims come off mine then ship mine down to u . That way I only need 2 iroc rims instead of 4 *grins*
Old May 23, 2005 | 07:39 PM
  #95
StevenK's Avatar
Car: 91 Z28
Axle/Gears: 3.73 Hawks 8.8
Take off the rear end cover, and remove the axles with the wheels attached.
Then replace the axles.
If you want to use the rims, cut the axles off the rim.
I had my 4th gen wheels get stuck once, but that was my fault cause I knew they were going on too tight when I put them on....the inside of the wheel was a little too small for the hub.
the BFH on the inside of the tire took care of it in my case.
Old May 23, 2005 | 08:07 PM
  #96
kyles88bird's Avatar
Car: Trans AM
Engine: 305 TBI LO3
Transmission: W/C T-5
Axle/Gears: 3.42 Open
get the biggers sledge hammer u can find/buy. tie the rear end down so it wont move. take all the lug nuts off the rims. hit it at full force until u cant swing no more. if no luck, have some1 heat it up wit acell. torch. keep hittin it as u SLOWLY heat it up. or if u can get he axel out, heat the back side and then try hammering it off
Old May 23, 2005 | 08:08 PM
  #97
91Zman's Avatar
Car: 1991 Z28
Transmission: 4L60 automatic
Try this.. loosen the lugs and drive over some tall speed bumps.or do some donuts in a parking lot with the lugs loosened.
Old May 23, 2005 | 08:48 PM
  #98
JamesY's Avatar
Car: 86 Camaro
Engine: 2.8L MPFI
This board has an issue with reading and looking at pictures don't they....
Old May 23, 2005 | 10:24 PM
  #99
91Zman's Avatar
Car: 1991 Z28
Old May 23, 2005 | 11:13 PM
  #100
LMAO that ****s funny, the rear ends worth more then the rims....
borg, disc.... all get them off i dont kno how but im sure the more cerative side well come out of me
