Painting Your Brakes...
Old Feb 14, 2005 | 04:03 AM
Imadude_134's Avatar
Car: 1991 Camaro RS
Engine: L98 350 TPI
Axle/Gears: ZT LSD with 3.42 - LS1 brakes
Anyone here painted thier calipers/drums? is so, any pics? I was thinking about doing this to my 91 RS, does it affect braking in any way? Also, what color would look good on a black car, and where could I get the paint? Thanks for your help in advance.
-Tim-
Old Feb 14, 2005 | 05:09 AM
Spdfrk1990's Avatar
Im painting my calipers red and my rotors gray just mask off where the pads touch. Use hi heat paint vht sells its great stuff. Just do you self a favor and take everything off the car so u dont get paint on the hoses or pins and make sure everything is clean and rust free.
Old Feb 14, 2005 | 06:57 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
never painted em but I have powdercoated em for people.
Old Feb 14, 2005 | 07:45 AM
ssxmac's Avatar
Car: 89 RS
Engine: lo3
Transmission: 700R4 w/ B&M shift improver
Axle/Gears: 3.27 9-bolt posi
TPI383, check your pms...
I'd go some sort of silver/grey or if you've got some stripe or something on your car, you might want to try that color to help accent it.
-chillen
Old Feb 14, 2005 | 09:57 AM
TZFBird's Avatar
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
Paint them a color like the "cool" guys and go with a color that is as opposite as you can get.. I.E. yellow calipers on a black car or green calipers on a red car
Old Feb 14, 2005 | 11:40 AM
Demon355's Avatar
eww no don't do that...I repeat DO NOT ****-a-fy your car. Paint them black or a deep dark color. Never anything bright so you can see them from a mile away...there drum brakes...
Old Feb 14, 2005 | 12:38 PM
Stevo's Avatar
Car: Pair of 92 Z28s
im planning on painted my calipers this spring...not sure to go white or red...i think im gonna do white cause red is too much.
my car is white with red stripes and red interior
Old Feb 14, 2005 | 01:48 PM
ssxmac's Avatar
Car: 89 RS
Engine: lo3
yea, i wouldnt paint drums either. Maybe black, but definitly nothing bright, just looks....bad
-chillen
Old Feb 14, 2005 | 02:03 PM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
Here's a picture of my painted drums. I think black is the only color to go with if you paint them.
http://memimage.cardomain.net/member...8_121_full.jpg
Old Feb 14, 2005 | 02:06 PM
nick418's Avatar
Engine: L98, Hemi 6.2
i painted my calipers red, i think it looks good on a black car, the red/black combo
Old Feb 14, 2005 | 02:14 PM
Goumba T's Avatar
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
I used VHTs "Cast Aluminum". They don't look like rust when up close, but they don't stand out too much either.
Old Feb 14, 2005 | 02:25 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
I used high temp satin black....wouldn't go with anything else. Just depends what look yoru going for. If I had some big, nice after market brakes...it would be a different story. With the stock set-up....that's really not much to show off...
Old Feb 14, 2005 | 03:30 PM
pwdbychevy's Avatar
Car: 1991 Camaro Z28
Engine: Dart SHP 406ci T88 turbo
Axle/Gears: QP 35 spline Ford 9" 3.50 gears
Here's my LS1 rear brakes painted Hi temp red
Old Feb 14, 2005 | 06:39 PM
Alexcoqui's Avatar
Car: Trans Am "GTA"
My 1LE front calipers painted with the caliper paint from pep boys.
Old Feb 14, 2005 | 08:30 PM
Spdfrk1990's Avatar
Same color im paintin mine alex.
Old Feb 15, 2005 | 04:33 PM
Orinackra's Avatar
Car: 06 SRM M6 GTO, 98 Grand Prix GTP
I'm painting my ls1 rear with high temp red as well.
Old Feb 16, 2005 | 03:01 AM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
quick picture gotta love the red/black combo
https://www.thirdgen.org/techbb2/sho...ighlight=paint
Attached Thumbnails Painting Your Brakes...-c-documents-settings-adam
Old Feb 19, 2005 | 10:02 PM
Yossarian14's Avatar
Car: 1986 z28 and 1997 Disco
Engine: Lg4 305
Ya I painted I got the lip machined off the inside of my drums, rebuilt the rear, and then painted them. You can see them in a pic on here - http://www.cardomain.com/member_page...page_id=756169
Old Feb 19, 2005 | 10:59 PM
redraif's Avatar
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
Originally I went with high temp red, but as time went by they get dirty and stain...even darken over time, so the second go around I used automotive paint. Joe painted all my suspension and brake components with it! Same red as on the body! Its so much easier to keep clean now! All this was done with the disc brake rear swap! We removed everything to paint them and did a silicone fluid upgrade at the same time with new Earls stainless lines!
But for referance in this thread...here is the old drum set up!
Old Feb 20, 2005 | 02:22 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
I'd paint mine, but only a semi gloss black or graphite/gunmetal.
Old Feb 20, 2005 | 09:18 AM
SmokinBerlineta's Avatar
Car: 1982Firebird S/E
Transmission: th200c
youre car is at the top of my list as well as many others as the coolest car here at tgo
Originally posted by stitchop
I like mud flaps on third gens, but my father-in-law Uncle Jim Bob said they look trashy.
R.I.P 82Knightrider,heres his last post before ..well...A shadowy flight into the dangerous world of a man who does not exist,a man tryin to be unbanned......
last quote by 82KR before banned:
Originally posted by 82knightrider
I like the 91-92 nose but only in red or blue
see for your self at...https://www.thirdgen.org/techbb2/mem...o&userid=35390
Old Feb 20, 2005 | 10:21 AM
redraif's Avatar
Thanks!
Old Feb 20, 2005 | 12:09 PM
phoenix305's Avatar
Car: 1987 IROC, 1989 IROC
Engine: built 305, stock 305 tpi
Transmission: Corvette 700r4, t-5
Axle/Gears: 4.10 posi, 3.08 posi
i think you went over board with your car but to each his own, or i guess in this case her. I'm using that ceramic paint that you use a brush to apply its designed specifically to paint breaks, i'm doing red.
Hotrodboba400
Dec 10, 2019 07:07 PM
Drone358
Sep 21, 2015 08:54 PM
TheExaminer
Sep 6, 2015 11:40 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
