ZO6 wheel adapter question
Old Feb 24, 2005 | 09:45 AM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
I am looking at getting a set of 17x9.5 ZO6 aftermarket wheels.
It states an offset of 54mm.
What size adapters will I need to put these on my 88 IROC?
Old Feb 25, 2005 | 06:58 AM
Car: 1971 Camaro
Engine: 427
Anyone?
I did a search and all I could find was, " Most people use a 2" spacer, but some use a 2 1/2".
I contacted Jegs who sells the wheels in question, and they said the wheel has a 7" backspacing. Which would need a 1 1/2" spacer to attain the desired 5 1/2" backspacing.
Does this sound right?
Old Feb 25, 2005 | 11:19 AM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
Engine: Dart Little M Twin Turbo
I wrote a tech article, linked off the main page here at TGO:
http://www.skulte.com/adapterfaq.html
I'd recommend going with 2" or 2.25" adapters on all four corners. You could go thinner in the rear, but then the rims will tuck in more than the front, and most folks liked to have them even. They shouldn't stick out at all with 2.25", and a 54mm offset, and would give you plenty of clearance against the strut in the front. It seems GM's tolerances make rims sit differently in different third-gens, so sometimes it ends up being a trial and error thing. Also, I've got no problem exchanging them for a different size, if you're not happy with the final fit.
Andris
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
redmaroz
Aug 16, 2015 11:40 PM
Elliswon
Aug 10, 2015 12:33 PM
