Cleaned up passenger side valve cover on TPI engine
Old Mar 25, 2005 | 01:45 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
I recently cleaned up my engine prior to dropping it into my 84 T/A. The wiring and coolant line mess above the valve cover was insane! I found out that the coolant valve was linked to the A/C system that I've removed, so I got rid of the valve too. I'm also going with headers without AIR tubes, so the associated box has been removed. As soon as I get an AC Delete pulley, the compressor and air pump will be removed as well. Well here it is:
Attached Thumbnails Cleaned up passenger side valve cover on TPI engine-n-ta-my-bird
Old Mar 25, 2005 | 01:49 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
I also ran new wire loom to the injectors and rerouted the wires that go to the starter. They were originally routed from the rear of the engine, over the valve covers, down between the accessory brackets, and along the bottom of the head to the starter. I cut about 1-2 feet of length off and went directly down behind the head and to the starter. As a result, the wire loom above the valve cover is about 1/2 the diameter of what it was stock. I also placed it behind the PCV line.
I still have to add one coolant line that will go from the throttle body to the heater box, but it should still look pretty clean when done. I cleaned the valve covers the best I could, but they're scratched up and I'll be looking to replace them. The dent in my runner is also driving me nuts. I'll look to get a new runner and polish the TPI for next year.... right now I just want it in my bird and running! Let me know what you think
Old Mar 25, 2005 | 02:21 PM
Sonar_un's Avatar
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
I think there was a "golf ball" trick to removing the dent in the runners. I would give that a shot.
Old Mar 25, 2005 | 03:37 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
You have my interest... what's the "golf ball" trick?
Old Mar 25, 2005 | 05:08 PM
pennylessz28's Avatar
Car: www.hrfbody.com
Engine: www.hrfbody.com
Looks good. You planing on painting any of that?
Old Mar 25, 2005 | 05:51 PM
Sonar_un's Avatar
Car: '86 T/A
Well... as it turns out.. the runners are actually smaller than a golf ball, so that won't work.
After some searching I found a guy who put a hammer in a vice upside down and worked out the dents that way. They turned out pretty nice too.
Old Mar 26, 2005 | 02:19 AM
Spdfrk1990's Avatar
Golf ball trick hmm isnt that off south park lol
Old Mar 26, 2005 | 07:49 AM
CrazyHawaiian's Avatar
Car: too many ...
Nah, what they do is take some metal ***** (lol) and push them through the runner to straighten the dent out. I got a runner with some dents too. I used it to try polishing for the first time, good learning experience.
Old Mar 26, 2005 | 06:39 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
I remember the early Vettes had a really clean looking TPI engine, well engineered. For some reason the Camaros were pretty trashed up with all the hoses and wires right on top of the engine. Looks much better to have all that stuff tucked away to gone completely.
Old Mar 26, 2005 | 07:26 PM
vortech305's Avatar
This Golf Ball trick
http://cgi.ebay.com/ebaymotors/ws/eB...sPageName=WDVW
Old Mar 26, 2005 | 09:30 PM
Demon355's Avatar
Can I just remove my A/C? I don't need a different pulley? I want it gone!
Old Mar 26, 2005 | 09:40 PM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
doh! sorry double post..
Old Mar 26, 2005 | 09:45 PM
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Transmission: TH350
Steve this is why I have the group purchase on sogm.ca in the Classifieds. It is the A/C delete pulley. All you need is this setup and a different belt, and get rid of the A/C compresor and everything else. Makes for a much cleaner and less cluttered engine bay.
Old Mar 27, 2005 | 11:44 PM
82knightrider's Avatar
Transmission: TH200C....700R4
nice
Old Mar 28, 2005 | 09:32 AM
JeremyNYR's Avatar
Car: 1984 Trans Am
I may be taking off the valve covers and repainting them before installing the engine and tranny. I want to get under there anyways to lubricate the valvetrain since the engine hasn't been run in nearly 2 years. I'm also going to replace all of the coolant lines with new hose. As for the TPI itself, it's gonna stay as-is for this year. At this point, I just want to drive it ASAP so I'll work on improving it's appearance next year.
Those metal ***** are kinda pricey on Ebay at $50. I could probably replace the dented runner with a good condition used one for less. It's a decent idea though.
Old Mar 28, 2005 | 08:07 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
If you're going to replace the runners anyway, might try an old motorcycle trick. Real common to beat up an expansion chamber on the dirt bikes. Rig up something to seal the ends, put some air pressure in the pipe and heat the dented area until it comes out. Have to heat steel nearly red hot, but the aluminum should need much less heat.
Old Apr 6, 2005 | 08:13 PM
Red WS6 Ram Air's Avatar
Car: 90 ws6 formula
Engine: 305 tpi
Transmission: t-5
Could you or anyone tell me more about this coolant valves purpose and how exactly to route the hoses after removel?
Old Apr 6, 2005 | 08:54 PM
Abubaca's Avatar
The heater control valve (HCV) is vacuum activated and it sends coolant from the intake manifold, directly to the heater core (when open) where it then gets routed back to the radiator.
When the valve is closed, the coolant does NOT go to the heater core, but rather it just loops back to the radiator.
If you look at the HCV, you'll easily notice the one line coming of the side that comes from the manifold. on the other side you'll have two lines. You'll see one runs to the heater core/firewall, and one runs down to the frame rail where it intersects with the heater core return coolant line.
The HCV delete mod has one line running from the manifold directly to the heater core, and one line running from the heater core back to the radiator. This means you'll ALWAYS have hot coolant running through the heater core. Originally I thought that even with the heat OFF, you might feel some warm air coming out of the vents but this is NOT the case. I think this is a GREAT mod and it really cleans up the engine bay.
I have NO AC, NO emissions and NO HCV. I can easily reach down the passenger side of the motor and grab the Y pipe!!!
Here's a cool diagram. If I'm not mistaken, the oil cooler routing is slightly off, but it clearly shows the HCV and how it's routed.
Attached Thumbnails Cleaned up passenger side valve cover on TPI engine-engine-cooling.jpg
Old Apr 6, 2005 | 09:18 PM
Car: 90 ws6 formula
Engine: 305 tpi
Transmission: t-5
Thanks man, i think that im going to do this mod when i delete my a/c and lt1 intake swap next week!
Old Apr 7, 2005 | 04:15 PM
phoenix305's Avatar
Car: 1987 IROC, 1989 IROC
Engine: built 305, stock 305 tpi
Transmission: Corvette 700r4, t-5
Axle/Gears: 4.10 posi, 3.08 posi
So let me get this straight in your diagram it shows HOT coolant running to the oil COOLER am i missing something?
Old Apr 7, 2005 | 05:35 PM
Abubaca's Avatar
Well the oil cooler is worthless for the most part, at least from the factory. Anything is better than nothing I guess.
It's actually NOT my diagram, but I've just done some checking, and it IS correct. I had originally thought the OC was a little off, but it's right.
Old Apr 11, 2005 | 10:42 AM
JeremyNYR's Avatar
Car: 1984 Trans Am
yup, the diagram shown is exactly how everything was set up on my engine from an 88 Formula 350. I've thought about just pulling the engine oil cooler because it appears useless. It doesn't really get in the way though. The only thing i need to do now is to get the hard line that runs on the passenger frame rail and doesn't have an opening to attach the line to the bypass valve. I have the part #, now I just have to see if it can still be purchased anywhere.
Old Apr 11, 2005 | 08:55 PM
85z28guy's Avatar
Car: 85' Z28
Engine: 383 roller
Axle/Gears: Ford 9" 3.70
I always wondered how the hell people manage to dent the runners anyways?
Ikes 91Z
Dec 9, 2015 03:49 PM
NBrehm
Aug 25, 2015 11:49 PM
db057
Aug 22, 2015 08:17 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
mustangman65_79
Aug 8, 2015 01:18 AM
