Plenum polishing questions
Old Apr 19, 2005 | 07:08 PM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
2 quick questions....
1. Is the TPI throttle body plate aluminum? Can it be polished?
2. When painting the grooves in the plenum, should I use engine paint or is regular rattle can paint good enough? Does the plenum get too hot?
Old Apr 19, 2005 | 09:04 PM
TunedPort 335's Avatar
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
TB plate is aluminum yes and can be polished
I used high heat engine paint on mine, the plenum gets pretty hot... but i'm **** about that stuff
Old Apr 19, 2005 | 10:43 PM
jojo22's Avatar
Car: 91 firebird
Engine: undecided thinking 383 stroker
Transmission: ??????????
tuned lets see an engine pic
only cause 1) i love you car 2) i havent seen your engine 3) it might help this person to see others
Old Apr 20, 2005 | 06:54 AM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
Would be cool if he did post an engine pic, but not necessary. He did answer my questions.
Old Apr 20, 2005 | 09:31 AM
Old Apr 20, 2005 | 10:28 AM
jojo22's Avatar
Car: 91 firebird
thanks that was perfect
86IROC112
Sep 29, 2015 04:07 PM
gixxer92
Sep 1, 2015 04:32 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
kah992
Aug 19, 2015 02:55 PM
redmaroz
Aug 16, 2015 11:40 PM
