stock wheel clearcoat
Old Dec 27, 2000 | 04:56 PM
squirrelybird's Avatar
I have the OEM 15x7 rims on my 91 bird. Did they put some crappy clearcoat on them or something? Mine sorta cracking so the wheels always look dirty er crappy. How could I solve this problem? Is there any way to strip the clear besides sand/media blasting?
Old Dec 27, 2000 | 06:26 PM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
Get some Aircraft paint remover. It's harsh, so use gloves, but it's the best.
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
Old Dec 27, 2000 | 10:00 PM
formula90's Avatar
Car: 1990 Formula
Engine: 5.7 liter
ok...this is what i did..
taped up the inside painted areas with masking tape, apllied a thick coat of aircraft remover with a paintbrush, let sit for a hour and a half, useed a scaper to scrape the slime off, used water hose to spray of everything else, used 600 grit sand paper to rub out any blemishes, then used mothers rim cleaner to polish and buff. everything can be found at your local autoparts store.
I have experience...unfortunatly,its a result of bad judgement.
click below to check out MY FORMULA PAGE!
http://www.formula350.com
or click below to email me
astralbaby11@hotmail.com
Old Dec 30, 2000 | 08:22 PM
AaronRS305's Avatar
If you remove the clearcoat, will your wheels get diry a lot easier, or be harder to clean??
1992 Camaro RS L03
Old Dec 30, 2000 | 08:29 PM
formula90's Avatar
Car: 1990 Formula
Engine: 5.7 liter
well if you spend time with your car at least everyother weekend, then you should not have a problem. but, as an alternative, after you strip the clear, and finish the rims, you can apply a new coat of clear and the maintenance should be easier...
Old Dec 30, 2000 | 08:30 PM
I have the same question. I read on some other post somewhere that after stripping and polishing them, you will have to polish them like every time you wax the car since it's bare aluminum and it rusts. Could you mebbe re-clear them? If so, how durable would it really be?
Thanks,
Evan
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
LT1Formula
Nov 16, 2015 01:13 PM
Catcher55
Aug 15, 2015 07:08 PM
mustangman65_79
Aug 9, 2015 03:00 AM
