New way to remove rust.
Old May 19, 2005 | 10:35 PM
92rs85berlintta's Avatar
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
Anyone ever heard of electrolyic rust removal. It works good from what i hear. It pretty much is just a big trash can some washing soda and some stainless steel. A guy i work with is big into mg stuff and he says he uses this to clean all his parts. he took a 50 gal trash can and a sheet of stainless steel and lined the inside with it. next he adds water and the washing soda. he connects one side of a battery charger to the stainless above the water of course and the other terminal connects to the part by a rod. of course dont touch them together. Its so safe you can stick your hand in the water. anyone else ever heard of this??heres a better idea of what im saying
Old May 19, 2005 | 10:51 PM
JamesY's Avatar
Car: 86 Camaro
Engine: 2.8L MPFI
Transmission: 700-R4
Interesting thats forsure
Old May 19, 2005 | 10:53 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: New way to remove rust.
Originally posted by 92rs85berlintta
washing soap
Washing soda, not soap. Sodium carbonate.
Old May 19, 2005 | 11:07 PM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
woops yes your right. I guess the soap would just make some fancy bubbles.
Old May 19, 2005 | 11:10 PM
Dynodan's Avatar
Car: 1992 firebird
Engine: 305tbi
We use a technique like that at work , but not for rust removal.
We use it to remove the burn and heat affect zone on stainless washers. Cleans them up really nice. This technique he is using is like having a cathode in your home heat tank I believe. The guy is exchanging electrons with the stainless . Ships in the navy use this thats why the hulls last for ever. I am not sure how long this would last. I am the more cut it out and gut it type. I belive if it was really good alot places would use it?
Dan
Old May 19, 2005 | 11:16 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It's an electrochemical reaction, just like using an acid (phosphoric acid a.k.a naval jelly, or vinegar) to reduce the iron oxide. Connecting it to electricity just makes it happen faster (or in some cases makes it happen where normally it wouldn't).
JamesY's Avatar
Car: 86 Camaro
Engine: 2.8L MPFI
Makes me wanna try it, once I get my pos running first.
Old May 19, 2005 | 11:34 PM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
It has no harmful effects to metal unlike acids and naval jellys wich weaken metals.
Old May 19, 2005 | 11:38 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Vinegar and naval jelly aren't powerful enough to weaken steel or iron.
Old May 22, 2005 | 01:46 PM
GOY's Avatar
GOY
Car: Formula, a big red brick.
Engine: A Ford 351 Windsor... ?
Transmission: Dodge 727
Too bad getting an 15 x 15 foot pool is impractical, otherwise I'd just dip my car.
Old May 22, 2005 | 02:14 PM
JamesY's Avatar
Car: 86 Camaro
Engine: 2.8L MPFI
hahaha :P
You could do it, might be abit costly but hell, if it works and you had other people who wanted to do it, split the costs. I'm still trying to find a smaller part or somethign to do it on, i will letcha know if it works and maybe do some pics and stuff too
Old May 23, 2005 | 12:37 AM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
here's another how to link. http://antique-engines.com/electrol.asp
Old May 24, 2005 | 03:36 AM
madseen's Avatar
Car: 89 RS Camaro
This is the same treatment we used to use to clean jewelry when I was a salesman. You just gotta be sure to rub it down with some sort of compound after because metals will tarnish quick after.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
my86bird
Oct 23, 2015 12:20 PM
m00n420
Sep 11, 2015 02:39 PM
Stroopwafel
Sep 11, 2015 06:38 AM
Stryker412
Sep 7, 2015 09:11 AM
