Wheel Polishing Questions
Old Jun 13, 2005 | 10:35 AM
JB22's Avatar
So, let me first say, I have a new found respect for Aluminum Polishers... Wow its a buttload of work.
With that being said, I recently undertook the task of refinishing my 88-92 Iroc Wheels. I stripped all the paint off and started the process of sanding and polishing.
I did the 180/320/400/400wet and I buffed Tripoli then White Rouge (using different wheels)
I had kind of a dull finish, I wasnt really pleased with how it looked.
I took a little mothers to it and It made it shine quite a bit more, but I understand that anything that removes the oxidation and turns black isnt the way to go for a mirror like finish.
What do I need to do to get it finished? Waxing with Carnabu? If that is the case, where do I get a solid brick like the FAQ says?
I'll post some picks later
Old Jun 13, 2005 | 03:03 PM
little P's Avatar
Car: 89 Formula
Engine: 350ci, tbi
I just used Maguirs pure carnuba, anyway
welcome to the club
Old Jun 13, 2005 | 03:12 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
keep going with the two steps tripoli and white rouge you will get a mirror shine using them two polishes. you will see it close to shine with the tripoli and then when you start with the white rouge it will take out the grey shine to the fine white shine you want. don;t need the meguires or carnuba at this point. use the carnuba when 100% done to protect them.
jeff
Old Jun 13, 2005 | 03:15 PM
phoenix305's Avatar
Car: 1987 IROC, 1989 IROC
Engine: built 305, stock 305 tpi
Transmission: Corvette 700r4, t-5
Axle/Gears: 4.10 posi, 3.08 posi
try sanding them with higher grit sand paper it will bring them to a more mirror finish.
Old Jun 13, 2005 | 03:19 PM
JB22's Avatar
How many times do I got back and forth with Tripoli and White Rouge? And how do I know if I got the right amount on the buffing pad? I just kinda ran the pad on the stick of compound till I could see it. I noticed that the pads were getting a black film on them as I went along, is that normal?
Sorry for the noob questions.
Old Jun 13, 2005 | 05:46 PM
JeffW's Avatar
Engine: 305 tpi LB9
yep perfectly normal, it should turn black. hard to guage how much you need but if you have to much on the wheel it will leave alot on the wheels and not do a good job of buffing.
jeff
Old Jun 13, 2005 | 07:34 PM
JB22's Avatar
Alright, I spent another 3 hours or so going back over that wheel today. Still have to 400 wet, then buff. Will let you know how it turns out
Old Jun 14, 2005 | 06:44 PM
JB22's Avatar
I wetsanded today, and spent more time buffing, my problem before was I didnt buff it long enough. It looks damn good now. I need to go over it with White Rouge, but it looks real good with just tripoli. Gonna go take a picture now before it gets dark.
I just picked up some new wheel centers on ebay to replace the old cracked ones I have... that will help too
Old Jun 14, 2005 | 07:01 PM
JB22's Avatar
heres a pic
Yes I know the caliper looks like crap, I still need to steel wool the center parts of the wheels and the lug nut areas. After that I plan to clean up the calipers and rear drums and paint them red.
Lots of work to do, but im heading in the right direction
Old Jun 15, 2005 | 12:16 PM
Psycho_91Camaro's Avatar
Car: 1991 Camaro RS
Engine: THE LT1 SWAP SHALL BEGIN!!!!
Transmission: 700 R4
Axle/Gears: LSD! =(
I just use mothers... im missing my i-rocz center cap
Old Jun 15, 2005 | 01:46 PM
JB22's Avatar
Yours look good.
I dont think I am going to repaint mine, just going to steel wool between the spokes to get the tiny bit of paint residue gone.
I still need to buff with white rouge, but I am real pleased so far.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
kah992
Aug 19, 2015 02:55 PM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
