Before and after!
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
looks good...paint came out nice..... should polish the plastic on the turn signals would help clean it up a little more.
jeff
jeff
Car: 1987 F150...PAAARTY FOUL!
Engine: 300 I6 stump pullin sumbiscuit
Transmission: 4 speed grind box
Axle/Gears: 3.55 unlimited slip differential
man that is a SHINY paint job...someone must have doubled up on the clearcoat and prepped that sucker RIGHT! either that or you have a REALLY good camera, lol. i would polish the turn signal lenses like mentioned above and ditch the base model/RS grille. i have never been a fan of the hood you have (just looks too busy with the holes in the sides, the cowl AND the IROC louvers) but i love how you painted inside the holes red...that makes it actually look pretty nice on your car...good job man!
Josh
Josh
Car: 1989 Iroc-Z / 1985 Camaro
Engine: 5.7L 350 / 2.8L V6
Nice, I really like the red vents on the hood. Where'd u get the hood and how much? I've been considering that one too.
Car: 94 Camaro Z28
Engine: 5.7L
Axle/Gears: GU5 3.23
In all actuality, this is a picture of the car before I bought it, when I was just considering it.
screaminformula: I would love to grab one of those -camaro- grilles and swap it out! In the meantime, I just repainted the stock one to bring it back to life.
ddn69: I didn't paint it myself, but I did a month's worth of grueling prep work to save on cost! It was painted locally by a not-so-well known shop. I think they do beautiful work.
Lazer: I actually picked the hood up from a fellow TGO board member, named John in RI. He was a really cool guy and held it for me so that I could make the drive from CT to RI and pick it up. I got it pretty cheap, but I did have to do some fiberglassing on the surface and also around one of the bolt holes to correct a problem.
THANKS EVERYONE FOR THE COMPLIMENTS!!
Car: 94 Camaro Z28
Engine: 5.7L
Thanks a lot guys! I think it's coming a heck of a long way from its start. And to think the only thing I planned on doing was replacing the gas tank!!
Car: 1987 IROC, 1989 IROC
Engine: built 305, stock 305 tpi
Transmission: Corvette 700r4, t-5
Axle/Gears: 4.10 posi, 3.08 posi
you should have left the banner and pins off. It looks awesome either way man, good job.
grid style taillights, tinted windows, and a new front grill will set it off very nicely. Looks very good though, you would never know it was the same car. Im not sure how that hood works, but my brother has the same one and it doesnt have the louvers on it, kind if like the early z28 hoods, I think it looks better without the louvers.
Car: 94 Camaro Z28
Engine: 5.7L
EjBaL: I think that actually does look very nice without the louvers, i'd love to see a picture from more of a distance. I would go that way, but it would require a bit of work to flatten out the areas where the holes are, and then to fill in the holes themselves with fiberglass yada yada. Then I would have to rough it up and have it painted again lol and considering its for sale, I wouldn't trouble myself. Definitely looks great without though.
