Valve stems chrome or black?
Old Jul 20, 2005 | 02:39 PM
Mike1's Avatar
I've got a nice set of ROH ZS wheels polished. When I first got these I ordered them mounted/balance shipped to me and they had the chrome valve stems. So today I have to buy new tires and when I get the car back the put the plain black rubber valve stems in. I didn't say anything cuz it took soo long and I was ready to go eat lunch but these things just seem to stick out like a sore thumb to me. Should I have them put the chrome ones back in? I got to go back later on to get an alignmnet after I put new struts and strut tower bearings in. They can change the valve stems without taking the tire off the rim right?
Or am I just being to **** about this?
Later, Mike
Old Jul 20, 2005 | 04:56 PM
phoenix305's Avatar
Car: 1987 IROC, 1989 IROC
Engine: built 305, stock 305 tpi
Transmission: Corvette 700r4, t-5
Axle/Gears: 4.10 posi, 3.08 posi
wrong they have to dismount the tire to replace the valve stems but if you're not happy with them i would definitly make them do it. The chrome ones sound like they would look a ton better to me anyways.
Old Jul 20, 2005 | 05:10 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
if you want chrome, by all means go back and have them put chrome ones in. They should be able to do it without rebalancing the rim (if they're experienced) but they will have to break the seal on the front face of the tire. It would've been nice if they asked you if you wanted to keep the chrome ones since they came in with them, but you really need to tell them if you want anything special.
Old Jul 20, 2005 | 06:23 PM
Stevo's Avatar
Car: Pair of 92 Z28s
ok ive never heard of actual chrome valve stems...just the chrome part that goes over top of the stem...not the cap its like a tube i have some on my car.
but yes if there is such a thing as chorome valve stems completely they need to dismount the top bead of the tire.
Old Jul 20, 2005 | 08:01 PM
Mike1's Avatar
Oh... so is it just a sleeve that fits over the rubber stem? I've seem them sold as chrome stems before and my old ones did have a rubber base where they came through the rim but the rest was chrome. And I just washed the car and just keep lookn at the rims and for something so small they just dont look quite right anymore.
Old Jul 20, 2005 | 08:06 PM
kyles88bird's Avatar
Car: Trans AM
Engine: 305 TBI LO3
Transmission: W/C T-5
Axle/Gears: 3.42 Open
they are just a cover, most ricers stores have them. all u do is unsrew the cap, slide the sleeve over the stem, screw the cap back on. or if u want, have them put the bolted down valves stems in, they usually are used for truck tries but they come in silver so they prob blend in better
Old Jul 21, 2005 | 12:45 AM
83Firebird420's Avatar
Car: 87 GTA 120,000k, 90 CRX Si
Engine: 5.7 TPI, 1.6L 16 valve SOHC
Transmission: 700r4, 5spd std
Originally posted by phoenix305
wrong they have to dismount the tire to replace the valve stems.
Wrong. They dont have to dismount the tire if they have a good machine. I do this everyday, if its a low profile tire then yes u might have to dismount it, but with the machine I use at work I dont have to dismount the tire to replace the stem.
Old Jul 21, 2005 | 12:49 AM
and yes take it back and tell them u want chrome stems. they should have asked u or just have put chrome ones on the first time
Old Jul 21, 2005 | 06:43 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
I used to work at Sears and when a car came in with nice rims, we'd just put chrome ones on automatically. Or if chrome came out, we put chrome back in.
If you do wind up going back, tell them you want them rebalanced. They could probably do it without balancing them, but thats pretty lazy. They should have known to put chrome ones in in the first place.
Old Jul 21, 2005 | 08:05 PM
the crome ones dont wiehg anymore than the rubber ones. all they are is metal sleeves over the rubber part with a chrome valve cover. it hsouldent knock the balance out at all
Old Jul 22, 2005 | 05:55 AM
Car: 1989 IROC-Z
Engine: 383 stroker
It may not weigh much more, but its impossible for them to not way any more at all. I'm just picky and if someone was breaking down my tires, I'd want them to be rebalanced.
Old Jul 22, 2005 | 08:02 AM
JeremyNYR's Avatar
Car: 1984 Trans Am
i forgot that there are two different types of "chrome" valve stems. There are the two- piece ones that screw together which require breaking at least the outer bead of the tire to install. Then there's the sleeve style which is probably more common. It sounds like that's what you had before, so you should be able to get some sleeves to put on your existing rubber stems and not have to worry about bringing your car back in to swap stems.
Old Jul 24, 2005 | 02:29 PM
Mike1's Avatar
Thanks for the input guys. I found some sleeves for $3 and put them on. They look pretty close to what I had, though not exact. That sure beets trying to get back over there and take that much time just for stems.
Old Jul 26, 2005 | 02:01 AM
NEEDforSPEED's Avatar
never thot id see the day that we where worried about Valve stems,
chrome or black? lol
Old Jul 26, 2005 | 02:41 AM
Rabbitt's Avatar
Car: 1987 Iroc-Z
Engine: 355
Transmission: 700r4 w/ about 7500 miles on rebuild
meh, i'd say chrome on black rims and black on chrome rims
EDIT:: Sweet... 600 posts
1992 Trans Am
May 10, 2023 07:19 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
Exxon Limited
Aug 9, 2015 08:13 PM
