Tint questions
Old Aug 3, 2005 | 12:51 PM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
Transmission: Tremic6060
Axle/Gears: good enough
Tint questions
Alright, i got a question about tinting.. I got the rear defroster, and my experance with tint on the defroster grids aint that great, my geo had tint on and the tint on the defroster grid started bubleing, my question is, if i get this car tinted how long would it before i start experanceing the bubbling? and is their a way to not get the bubbling? thanks for reading this.
Brandon
Old Aug 4, 2005 | 08:48 PM
camaro05's Avatar
Car: 91 Z28
Transmission: built 700R4
if you get it done by a reputable shop, it should never bubble or change color. If it does then it should be covered by a lifetime waranty. Make sure you ask them about the waranty first.
Old Aug 4, 2005 | 08:51 PM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
Old Aug 5, 2005 | 06:58 AM
a mack6's Avatar
Car: 1992 Z28 (Heritage Edition)
Axle/Gears: 2.73 Posi
can someone explain to me why having the rear defroster may cause a problem when tinting??? I can't seem to figure it out...
Old Aug 5, 2005 | 09:07 AM
Tripper511's Avatar
Car: 1982 Trans Am
Engine: 350 4BBL
Transmission: 4 Speed Manual
I would guess it because there is heat coming from the electrical wires running through the window. I solved that problem by using a piece of tinted plexy glass that is the shape of my rear window. It just snaps in.
Old Aug 5, 2005 | 11:55 AM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
I believe your somewhat right, When the place tints your glass they take some water (or some simmilar liquid) and use it as a "glue" to keep it on the window.. now what happenes when you add heat to water? it boils correct? thats what i believe causes the bubbles.. and sorry if i came off rude with this statement.
Old Aug 5, 2005 | 12:49 PM
a mack6's Avatar
Now i got another silly question...
I know where the defroster button in my car is..its under the Lighter, but is that the rear defroster or do i have a front defroster?? IF it is the rear defroster ive never used it for some reason. So if i dont use it then i wouldnt even have to worry about waht the tint will do it.
Old Aug 5, 2005 | 12:58 PM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
its for the rear defroster.. the only frount defroster that these cars have is when you put the heater on the "Defroster" part. were all the air comes up out of the top of the dash.
Old Aug 5, 2005 | 01:04 PM
a mack6's Avatar
Oh well that makes sense. Yea i dont even use the rear defroster so i guess that wouldnt be an issue when tinting.
Old Aug 5, 2005 | 03:17 PM
camaro05's Avatar
Car: 91 Z28
I was told I should turn my rear defroster on after I got the windows tinted, The shop said it would help it dry faster. I have had no problems. I had boath my camaros tinted at the same shop.
Old Aug 5, 2005 | 03:24 PM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
how long have you had the tint on the windows? i know everytime i used the defroster on my previous car the tint got worse im gonna be taking it to a good tint place as soon as i get the cash
Old Aug 5, 2005 | 03:26 PM
camaro05's Avatar
Car: 91 Z28
I have had the RS tinted for over a year and I use the rear defroster all the time, even in the summer, early in the morning.
Old Aug 5, 2005 | 03:38 PM
Gr89RS's Avatar
Car: '02 Z06
My RS had tint on the defroster for 3 years and it never bubbled a bit. The defroster was used frequently during the winter months. Keep in mind when taking your car to the tint shop, some of the defroster lines may be broken when it is tinted and they will no longer work. My tint guy warned me beforehand that it may happen.
Old Aug 8, 2005 | 09:51 PM
greg18269's Avatar
Car: 89 camaro RS
Engine: 350 bored 3 over, edelbrock 600cfm carb,Edelbrock Performer intake,
Transmission: 700R4, shift kit
hey i also have a question is it posible to do tinting on bothsides of the window like the inside and the outside? would that make it twice as dark or what? just wondering
Old Aug 9, 2005 | 08:32 AM
Tripper511's Avatar
Car: 1982 Trans Am
Engine: 350 4BBL
Putting it on the outside would be a bad idea since it's just a matter of time until the outside elements rip it off.
Old Aug 24, 2005 | 09:53 AM
Firebat's Avatar
I have a question. Is 3M still a good brand of tint? What are some other good brands?
colton_carlson
Mar 8, 2019 12:21 PM
budofbama31313
Aftermarket Product Review
Sep 16, 2015 12:29 PM
Polo Z03
Sep 10, 2015 06:43 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
redmaroz
Aug 16, 2015 11:40 PM
