Polishing Runners ?
Old Aug 17, 2005 | 02:46 PM
Kaylyn831's Avatar
Car: 1989 Trans Am, 1986 Firebird, 1981 Firebird
Engine: 350TPI, 305, 265
Transmission: 5 spd & auto
Polishing Runners ?
Okay, okay I know this subject has been posted before but I wanted to know what everyone has used to get BETWEEN the runners when sanding.
Old Aug 19, 2005 | 11:09 PM
jack_sparrow's Avatar
Car: 1985 Camaro
Engine: 350 bored 40 over
Transmission: 700-R4 Race prepped
Use a quick search and it'll yield a lot of results. Besides youd get better info on the TPI board or maybethe FAQ's.
Brett
Old Aug 20, 2005 | 08:25 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
Just find something flat that will fit between the runners, and wrap some sand paper around it.
Old Aug 20, 2005 | 10:21 PM
QUICKCHICKEN's Avatar
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
use strips of stand paper as mentioned but use finer and finer grits to acheive the smooth look. also being the cast version wont take much to knock down you souldn't need much sanding.
Old Aug 21, 2005 | 08:37 AM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
i used a trip of sabd paper and pulled it back and forth.. hope that makes scence.... run the paper around the runner and put your hands on the other side of the curve of the paper and pull back n forth..
Linson
Oct 24, 2025 02:00 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
bigjay89gta
Oct 15, 2015 08:04 AM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
Royal_Z
Sep 30, 2015 08:45 PM
