rubber coating in engine compartment ???
Old Jan 28, 2001 | 03:37 PM
james_fearn's Avatar
The engine compartment in my 1985 Z-28 appears to have a rubber coating of some type and is not just painted. Does anybody else have this? Most pics I see appear to be painted the body color and not this rubberized undercoating type stuff. I don't think it's rubberized undercoating. Due to the completeness of the application and because the engine has never been removed from the vehicle (I knew the only previous owner) I think the car must have came like this.
Any thoughts?
James
1985 Z-28 305 TPI
220,000 mi., Original Eng.
Old Jan 29, 2001 | 12:04 AM
biscwgn's Avatar
I have a 86 Iroc with 19k miles i'm detailing the motor right now it has the same stuff under the hood, mine is painted but looks to have a glue or something sprayed over the paint its gold colored and is all over the whole motor compartment its tough to get off i thought it maybe a seam sealer or somthing but its there and a pain to get off!!!!!!!!!!
    [*]1996 TransAM conv(SOLD)[*]1995 Camaro rs(TRADED) [*]1977 Camaro LT(SOLD)[*]1973 Camaro RS (TRADED)[*]1973 Camaro LT (TRADED)
    Old Jan 29, 2001 | 02:45 AM
    stingerssx's Avatar
    Car: '88 Firebird Formula 350
    Engine: Built 383 TPI
    Transmission: Built 700r4
    Axle/Gears: 9 bolt, 3.27:1 Posi
    The previous owner sprayed it on. I would try to take it off if I were you. If you pull the motor, just paint the bay. The rubberized undercoating absorbs oil, and grease, then when you try to clean it, you can't. If it looks ok, then just leave it.
    '82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
    http://www.spinfrenzy.com/stingerssx...easures.html#4
    Frozer!!!
    Jan 19, 2024 04:55 PM
    1992 Trans Am
    May 10, 2023 07:19 PM
    customblackbird
    Aug 15, 2021 10:16 PM
    Terrell351
    Jun 13, 2021 01:13 PM
    bradleydeanuhl
    Aug 12, 2015 11:48 AM
