Paint coming off when buffing ??
Old Oct 9, 2005 | 11:22 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
Used a buffer today with Meguiar's Glaze (polishing glaze something .. i think this is the no.7)
Yellow foam pad .. low speed ... well the thing turns ... greenish.. i.e. ... my car color ... which is aqua/teal
Original paint job.. so probably not a lot of clear coat left
My question is ... am I right now buffing right on the base coat and actually removing it ?
I had this problem when applying wax before as well
Or is it a case of oxidized paint ?
Old Oct 10, 2005 | 12:09 AM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
By adding it happened also when applying wax.. I meant when applying with a terry cloth applicator .. wax.. by hand
Old Oct 10, 2005 | 01:01 AM
CrazyHawaiian's Avatar
Car: too many ...
Anytime the applicator pad turns the color of the car you are taking some of the basecoat off.
Old Oct 10, 2005 | 08:49 AM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
car may have beed repaint with a single stage paint so you will get paint color on your pad. loo real close at your jambs and mirrors and place tape edges could be. that will help you tell if its original base clear or single stage paint. do some digging remove some lights see whats behind em.
if its base clear and your getting color it time for a repaint as the base will not shine. if its single stage and its shining and looking even not splotchy then your ok. just keep in mind single stage will not last for ever with your buffing.
jeff
Old Oct 10, 2005 | 10:55 AM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
uhmmmm
Now that you mention it ... I do have a few not many but a few spots where paint has landed on top of the rubber seal .. hmmm I think around one door and perhaps T-top seal
I was just wondering .. since yeah I thought... color means... rubbing paint off
OK thanks guys ... I'll just be careful and do it lightly for now ... car needs a new paint job anyway but not right now .. not until after any body mods I may or may not do
Street Lethal
Apr 30, 2019 12:14 PM
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
neekolzun
Aug 24, 2015 04:59 PM
ElPaleterro85
Aug 13, 2015 03:49 PM
NBrehm
Aug 5, 2015 07:57 PM
