Switch to later style 3rd brake light...
Old Feb 8, 2001 | 08:13 AM
ERIC'86IROC's Avatar
Do I have to get a newer hatch to get rid of my '86 third brake light?
350 Vortec, forged flat-tops, CompCams XE268, Edlebrock RPM, Holley 3310, TH350 w/Holeshot 2400, 3.23 posi, Heddman shorties, HEI
Old Feb 8, 2001 | 11:56 AM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
No. You could always get an older hatch.
Seriously, you probably will have to replace the hatch because if you notice, the screws holding on the assembly go through the glass. Take it out and you got 2 1/4" holes for rain to get in!
86 Sport Coupe, 2.8 V6, dead stock, but not for long!
"Little girls play with ponies!"
www.geocities.com/camman86
Rock fans click the secret link on my site!
Old Feb 8, 2001 | 01:10 PM
86ZRICHIE's Avatar
Yeah, if you want to get rid of that light and put on say the spoiler style CHMSL then you're best off finding a donor hatch. Mine's kinda rigged in there. It has a hatch from a firebird (thanks to the last owner and someone with bad brakes) so I had to kinda rig the spoiler. Also, the holes don't line up. The only ones that do are the ones on the ends of the center piece. You're best off getting a hatch with the spoiler on it to save on filling, then all you have to worry abbout is the end pieces. This will also mean that the wiring is already in there and the spots for the hole plugs are in the right place which is a plus. My wiring's just running through a hole from the old spoiler o it doesn't look as good as it could
Old Feb 11, 2001 | 11:27 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
I agree with getting a rear hatch from a wrecked car. It will have the spoiler attached already and the spring loaded contact piece on the underside. You will also need the contact pad that attaches to the plastic trim piece below and need to wire it in. Also make sure the spoiler matches with yours. If it is wider you will need to swap the side trim pieces as well.
Frozer!!!
Jan 19, 2024 04:55 PM
mitch_04
Members Camaros
20
Sep 20, 2021 02:24 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
Eagle223usa
Brakes
Aug 14, 2015 09:24 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
