how to prep/paint engine and heads..
Old Feb 9, 2001 | 10:08 PM
Superblue87Formula's Avatar
I want to paint my motor and heads gloss black. What do I do to prep them and what kind of paint should I use? Do I primer?
1987 Formula 350, headman hedders, Accel supercoil, cap, rotor.
MAF screens removed. 160 degree stat and manual fan switch.
Best ET: 14.745@91.317mph-Stock
Best ET: 14.418@95.51 mph-Modded
Ridiculed Founder of the Traction Impaired Crew
Old Feb 10, 2001 | 09:15 AM
BOWTIROC's Avatar
From: Coulterville, IL...Currently on Beale AFB, CA
When we did my engine, we just prepped it with some final clean to remove all the oil and grease, then shot it with a couple coats of high build primer, then 2 coats of base and 2 of clear. has held up great so far
Black 89 IROC...Mods: 355, 10.5:1 comp, Big Solid Crower Cam, TFS heads, Victor Jr, Holley, and a 5 spd...
Old Feb 12, 2001 | 04:17 AM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
When I paint my engines, I just make sure that the block is clean of any oil. I actually paint it before I do any machining, then re paint it when I'm done. The "engine paint" that comes in a spray can works great. For one of my engnines, I used the stock GM blue, and did it this way. I was told that the paint would fade if I were to spray it first, but it didn't. Just some chips. So that's the only reason that I repainted it.
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
http://www.spinfrenzy.com/stingerssx...easures.html#4
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
