Removing crappy window tint, a question.
Old Feb 26, 2001 | 10:26 PM
87z28's Avatar
Just got a new(er) car today. Its a 91 Z. The car is awsome except that it has this really ugly, cheap, purpulish tint on the windows and a strip on the top of the winsheild and although it is not bubbling it is starting to peel around the edges. So can I just peel this stuff off and use a razor blade to remove any stuck pieces or is there a trick to get this stuff off my car? Thanks.
Old Feb 26, 2001 | 11:07 PM
theformula's Avatar
It's purple because it was once black. Cheap tint usually does this over time and sunwear.
My 3 year old black rear window tint just peeled off. However, that is the easy part.
The tint leaves a relatively thick adhesive on the glass once the actual "tint" is removed. This adhesive is the pain in the a$$ to remove. I tried "tint off", even full strength amonia with negative results. Know what worked? Gasoline! Just make sure you cover up your interior and wash the rear hatch after you're done so the smell doesn't stay in the car. But I assure you it will not.
Good luck. Hope you have about 4 hours and a lot of elbow grease to waste.
91 Formula
305 TPI 5speed
1LE/G92/WS6
Paxton SN92 polished kit, SLP airfoil, ported/polished plenum, March pulleys, Crane AFPR(43psi),Crane Gold 1.6rrs,MSD coil,MSD6AL,MSD boost-master,Holley 9mm wires,Ac delco R43ts plugs,custom chip,Ford SVO 24# injectors,Bosch O2sensor, Bosch in-line pump(w/stock pump), SLP 1 5/8" headers,SLP catback,short shifter,3:73s w/Auburn posi,170* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
Old Feb 26, 2001 | 11:57 PM
rydeordyeww3's Avatar
my advice is just wait till u get money to retint the windows and let them scrape it off. they might charge u about 50-60 dollars more but its worth it to me
Old Feb 27, 2001 | 11:55 AM
theformula's Avatar
Ryde brought up a good point. It is a pain in the a$$ to remove the old adhesive. They will charge you an arm and a leg probably
91 Formula
305 TPI 5speed
1LE/G92/WS6
Old Feb 28, 2001 | 11:15 PM
forsete's Avatar
I had the same problem with my '87 Trans Am.
What I did was drench the window with Windex (I think) and then, while it was still wet, cover it up with saran wrap. Let it set for at least a couple of hours, preferably over night. (The stronger the stuff, the less time you have to wait.)
Then just remove the saran wrap and the tint should just fall right off. You might want to have a razorblade ready in case it didn’t work all too well.
In any case, it will be much easier to scrape the tint off. Remember to cover the interior/trunk with newspapers so you won’t get dripping Windex all over the place or, scraps of tint…
Good Luck!
Old Mar 1, 2001 | 02:04 PM
Happy17yearold's Avatar
you can try to remove it with paint thinner.but be careful on not letting it hit the door panels or seat cause it might fade the color....but im certain that thinner and a razor will do the trick.....not lacquer..the strong one
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
RedLeader289
Jan 22, 2016 03:05 PM
Polo Z03
Sep 10, 2015 06:43 PM
3rdgenparts
Aug 8, 2015 07:09 PM
