HIDs on a Camaro
Old Mar 14, 2006 | 03:41 PM
Stevo's Avatar
Car: Pair of 92 Z28s
HIDs on a Camaro
So has anyone actually done a true HID conversion? I know theres been lots of talk but if anyone has actually completed it post up some pictures! I just think itd be so cool to see HIDs on a camaro because ive never seen it. So post up!
I myself run silverstars right now but am looking at converting to an H4 setup...id dream of having HIDs but they are really expensive to even set something up...
Old Mar 14, 2006 | 03:43 PM
jethawk's Avatar
Car: 1991 Firebird Formula WS6
Engine: LB9
Axle/Gears: 3.42's
are you looking at doing a full hid projector swap... or just a PNP kit?
Old Mar 14, 2006 | 04:01 PM
Lazer's Avatar
Car: 1989 Iroc-Z / 1985 Camaro
Engine: 5.7L 350 / 2.8L V6
I've seen 4x6 projector light housings before. If you got the bulbs and the ballasts I don't see why this wouldn't be possible.
Old Mar 14, 2006 | 04:08 PM
jethawk's Avatar
Engine: LB9
Axle/Gears: 3.42's
http://www.streetbeatcustoms.com/rectangle.html
that site has premade 4x6 lights with the projectors already retro'd in....i'm not sure of the quality of the projectors they use.... but for those prices you can pick up a set of used OEM projectors from another vehicle.. retro them into some free-form 4x6 H4 conversion housings and pick up some bulbs and ballasts.... probably for close to the same price they sell just their housings for.....
Old Mar 19, 2006 | 03:13 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Do sylvania Xenarcs count.Thats what i have on my 84Z.
Old Mar 21, 2006 | 09:21 AM
confucius101's Avatar
I'm just tagging along here
Old Mar 21, 2006 | 05:50 PM
@ZZKKER's Avatar
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
yes the xenarcs count! i have a question about the xenarcs, what style of base do those housings use, are they like an h1 or h4, or a special base like lots of the factory ones use?
Old Mar 21, 2006 | 06:44 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
They use a D1R or D2R(66052) Hid lamp.Nothing like a H1/4.There is no filament.I know some cars use these HID lamps as factory units, but i cant remember right now which ones!
Old Mar 21, 2006 | 08:17 PM
@ZZKKER's Avatar
i know they are nothing like a normal bulb. i think you miss-understood my question. What i was asking was: is the base of the bulb the same style as say a 9006 or an h1 (the part of the bulb that screws into the housing) because i was interested in these units but was curious if a catz bulb of a different color temp could be swapped in. that's what i was asking.
sorry for the confusion
thanks in advance
anthony
Old Mar 21, 2006 | 10:12 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
As stated above it is nothing like a H1/H4,9006 or any other kind of "standard" headlamp.Xenarcs use there own housing,base,connection.The base plugs into the Xenarc harness.The lamp/base seals onto the back of the headlamp & is retained by a two screws.There is no way to adapt these to your standard 4656 or any other kind of aftermarket xenon,or other so-called HID headlamp kits.
Old Mar 21, 2006 | 10:33 PM
Sleeper_Z's Avatar
Car: Golden yellow 1987 IROC-Z
I have the 4x6 H4 conversion lamps but you have to do some modification to the headlight bucket and you have to rewire the dim lights with a 3 prong connector befor you can install them. Im gonna have to get a 3.5 inch hole saw and open the headlight bucket up cause the large plug on the back of the aftermarket lamps hits it and wont come close to going in. Ill post pics when I get them installed.
Jeremy
Old Mar 21, 2006 | 10:38 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Id post a pic of the HID lamp (D1R) i have, but its such a pain now.The uploading keeps failing.
Old Mar 21, 2006 | 10:40 PM
Sleeper_Z's Avatar
that sucks. id like to see what they look like. I tried to install mine when they first came in. But the found out that i had to pull all the headlight buckets out and cut larger holes. So they are now sitting on a shelf in the garage waiting for nicer weather.
Old Mar 21, 2006 | 10:48 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
The Xenarc kit requires you to notch the headlamp bucket as well.This is so the cable harness plug clears the hole in the back of the bucket.
Old Mar 21, 2006 | 10:53 PM
Sleeper_Z's Avatar
I wish mine would have came with some kindof harness. Do you have a link to the kit you have?
Old Mar 21, 2006 | 11:32 PM
@ZZKKER's Avatar
the reason i was asking is because i would want to swap in a set of catz true HID 6000k bulbs to replace the 4500k ones that come with the xenarch kit. are the bulbs and ballasts separate or are they permanently attached like the GMC envoy HID setup (where bulb and ballasts are changed together), because generally the ballasts will outlast 2 - 3 sets of bulbs if the ballast is one of the good ones. this saves on cost when it is time to replace the bulbs, or if one desired to change the bulb temperature.
thanks
anthony
Old Mar 22, 2006 | 02:55 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
http://www.hidplanet.com/main.html
Lot's of deals on GOOD HID retro setups as well as a wealth of knowledge about d1s, d2s, etc.
I'd stay away from a catz capsule and go with a stock style capsule. Easier to replace later on. Different manufacturers (audi, bmw, caddy, honda) use different brand ballasts/capsules and different light color.
Old Mar 22, 2006 | 06:54 PM
@ZZKKER's Avatar
thanks for the link. so far i have 1 hid bulb and ballast from an escalade ( the bulb unplugs from the ballast cable) and 1 from a 99 gmc envoy (ballast and bulb are 1 piece, not good for retrofit). both of them use a Phillip's ballast.
every time a wrecked car that has hid's comes in, i check to see if there is headlight damage in the hopes to make a matched set.
thanks again
anthony
Old Mar 22, 2006 | 07:39 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
No link, but the sylvania website should have info/pics.They had the xenarc hid kits on there the last time i visited them. On the HID lamps,yes they are seperate form the ballast.Two ballast for 1 each lamp.A cable runs form the ballast to the lamps.Plus the harness that intergrates the factory harness to the xenarcs.Two relays 1 for each side of the harness.Its all plug & play though.So install is easy.Wow the pic uploaded ....here it is..I hope
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
BADNBLK
Nov 16, 2016 09:12 AM
porkenstein
Convertibles
Aug 31, 2015 12:54 PM
Fronzizzle
Aug 19, 2015 01:36 PM
