clay bar
Old Apr 2, 2006 | 02:37 PM
gta31's Avatar
Car: 87 gta
Engine: l98
clay bar
i have a black gta and the paint has a haze on the hood i was wondering if the clay bar will help at all until I get it repainted, I've tried wax and it does nothing
Old Apr 2, 2006 | 09:03 PM
DJCobol's Avatar
Car: '89 Black IROC 'vert
Transmission: 700-R4
Axle/Gears: 2.73 posi
If the haze you are referring to is Oxidation, then no, it wont. You will need a polishing compound to take care of that.
Old Apr 2, 2006 | 09:13 PM
gta31's Avatar
Car: 87 gta
Engine: l98
where can i get that at is it hard to use at all thanks for the reply , the car would look so much better if can that off
Old Apr 3, 2006 | 12:45 PM
86IROCKET-Z's Avatar
Car: 1989 Toyota Supra Turbo
Engine: 7M-GTE
Transmission: R154
Axle/Gears: 3.91 LSD
You can get rubbing compound at local auto stores, but you may want to look into automotive finishing stores around your area. They really know about body work and will be able to tell you exactly what you need. Also, using a buffer would make it really shine. Just make sure you be careful with it and don't burn the paint or hit edges.. It could throw the buffer out of your hand and scratch or dent your thirdgen.
I'd say to the Auto body supply co. that you were interested in buying it (even if you aren't) and see if they let you borrow it. If not, they will probably lend one to you for a small fee..
Old Apr 3, 2006 | 04:16 PM
CityStarz's Avatar
Car: not a third gen
Engine: L36
Transmission: 4T65E
Axle/Gears: stock 3.29
a random orbital buffer should prevent any chances of you scratching your paint
best bet is probably letting a detail shop do it though
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
