POR15 and the New Rear End
Not sure if this is the right forum, but hey.. .its appearance
you can check out pics here
Question is, Do I need to bother with doing the Topcoat on the Rearend considering its not going to be subjected to direct sunlight? If so, optimal bonding says to do it before the paint fully cures... anyway to do it now at this point? Scuff it up some and slap it on or??
In case anyone is wondering, I didnt paint the pumpkin cover because it was pretty rough, so im just going to pick up a new one from summit. I didnt paint the hubs yet because I needed to carry it back inside before I had to head back home. (doing work at my parents on the weekends)
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
I did the same thing about a month or two back when I got my 4th gen rear. You can really tell the difference. The only thing that I don't like is if there is a part where the POR didn't adhear too well it will peel off in a sheet instead of flaking/cracking. I did put a topcoat of PORs ChassisCoat about a week after I did the POR 15. It adheared pretty well. Here are some pictures of mine:
Before
After
Before
After
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
lookin good! i just painted my rear this weekend using POR-15. i metal readied it friday night, and painted saturday.. used 2 coats on it. turned out ok
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
wow looks pretty sharp.
hear great things about that por 15.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
