white rims?
Old Apr 24, 2006 | 10:46 PM
rover420's Avatar
Car: 88 camaro
Engine: 3.4
Transmission: t-5
Axle/Gears: limited slip posi 3.42
white rims?
anyone know if u can paint these white (stock 88 rims if u can't see them)
Old Apr 25, 2006 | 11:46 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
dude, you can paint those frickin' shartruse if you want! lol! do whatever, they are your wheels!
but if your asking if they cam from the factory like that, yes, they did. the spokes and in between the spokes were white, the star where the lugnuts go were black and the lips were polished. let me look through my cardomain pics and see if i can find some pics of my first car that shows the wheels well.
Old Apr 25, 2006 | 12:00 PM
mw66nova's Avatar
Engine: 7.0L
found one, it's not the best picture in the world, but you can atleast see what i'm talking about:
Old Apr 25, 2006 | 05:55 PM
rover420's Avatar
Car: 88 camaro
Engine: 3.4
Transmission: t-5
lol cool **** i thought they came like that stock but i was looking threw a site and all they said they had for 88 were the rims i posted. would happen you know type of paint u think would be best that?
Old Apr 25, 2006 | 06:00 PM
mw66nova's Avatar
Engine: 7.0L
i use duplicolor wheel paint. it's about $5 a can though O'reily auto parts, though i'm sure you can find it at an advance auto or pep boys or autozone.
Old Apr 25, 2006 | 06:03 PM
rover420's Avatar
Car: 88 camaro
Engine: 3.4
Transmission: t-5
cool **** i just didn't know if it would turn out since it's more of a rougher type rims. I just wasn't sure if it was gunna stick to it properly without sanding and junk. thanks dude
Old Apr 25, 2006 | 06:14 PM
purpleZ-28's Avatar
Car: 85 Z28, 88 GTA, 68 Cutlass S
Engine: 305TPI X2 ;), Chevy 250
Transmission: T5, 700R4, powerslide >:(
Axle/Gears: posi, and posi w/discs :D.
personnaly id go and have them powder coated. itll hold up the best, its deffinetly more expensive, but the thing about powder coating is you cant really mess it up at all, and itll last forever.
Old Apr 25, 2006 | 06:18 PM
rover420's Avatar
Car: 88 camaro
Engine: 3.4
Transmission: t-5
i might be mistaken but don't they have to run electrical currnt threw the rims to attract particles that just mists over it? these rims don't look like they will have a good currnet goint threw them.
Old Apr 25, 2006 | 06:40 PM
purpleZ-28's Avatar
well first you abviously have to sand blast the wheels, then after that, all i know is they spray on a sort of dust type paint, and cook em. as long as something is metal, it can be powdercoated
Old Apr 25, 2006 | 06:58 PM
mw66nova's Avatar
Engine: 7.0L
yeah, you can powdercoat these just like anthing else, though it's gonna cost much more to powdercoat then just spray paint. the duplicolor works REALLY well. i used it on my front wheels for the drag strip (cause i don't have the $$ to get matching front wheels) and it looks amazing! i then went back over the whole wheel with a clear coat, again, using duplicolor.
here ya go, though i don't know how well you can see the quality of the paint job:
Old Apr 26, 2006 | 08:22 PM
rover420's Avatar
Car: 88 camaro
Engine: 3.4
Transmission: t-5
where those the same as in the picture i first posted?
Old Apr 26, 2006 | 08:28 PM
Jgolden314's Avatar
Car: 1999 Z28
Transmission: A4
Yep.
Old Apr 26, 2006 | 08:51 PM
mw66nova's Avatar
Engine: 7.0L
i couldn't tell ya if they are the exact same wheels, i've had about 5 sets of those wheels at one point, and they've all been painted at one point. lol! here is another picture, hopefully you can see how i wetsanded and polished the lips to a mirror finish.
Old Apr 27, 2006 | 04:08 AM
purpleZ-28's Avatar
its true, powdercoating is alot more expensiv, but im more of a quality kinda guy. i guess it depends what this is going on. street car, show car, daily driver, drag car etc..
Old Apr 27, 2006 | 07:45 AM
ahusted's Avatar
I know you posted how you prepped your wheels for paint....but now I can't find it!!!
I want to color match a set and yours look great!!
Can you give a brief run down on how you prepped the wheels and how long the finish holds up?
I had talked to a couple of guys about powder coating, and they were afraid of doing used wheels in a light/white color. They said it is very hard to get used aluminum wheels really clean and that imbedded brake dust might show through after the curing process.
Old Apr 27, 2006 | 10:28 AM
mw66nova's Avatar
Engine: 7.0L
aircraft stripper to strip all the old clearcoat and paint off. once stripped, start with 220grit wetsand paper on the lips, getting all the grooves and pits out of the aluminum. move up to 400, then 600, then 1000, then rubbing compound and polishing compound. then you'll want to make sure everything is VERY clean. once the wheel has dried, tape off the freshly polished lips (be patient, but they they WILL look like mirros) and paint the center black. then, after two coats of black,(and they've dried) tape off the center as to not get your fresh black center oversprayed with whatever color the wheel is going to be (disregard if your painting the whole wheel black like i did). put 3 coats of base down and 2 coats of clear...allowing for them to really dry between each coat, 15-20 mins would be acceptable. once everything has dried, peel your tape off. it's much easier to do this with no tire on the wheel, but i did my fronts with the tires still mounted.
Old Apr 27, 2006 | 01:59 PM
rover420's Avatar
Car: 88 camaro
Engine: 3.4
Transmission: t-5
i was planning on just painting the whole thing white lips and all. U think i would still have to sand it down?
Old Apr 27, 2006 | 03:35 PM
Jgolden314's Avatar
Car: 1999 Z28
Transmission: A4
I would.
Old Apr 27, 2006 | 04:34 PM
mw66nova's Avatar
Engine: 7.0L
it'll go from classy to cheesy if you paint the whole wheel. i promise you it will look 100% like crap. take your time and prep the wheel like i said or it will look like some 16 y/o kid got impatient....these types of things take time.
Old Apr 27, 2006 | 07:08 PM
rover420's Avatar
Car: 88 camaro
Engine: 3.4
Transmission: t-5
so basically instead of the black i switch with white and do the mirror finish on the rims to give the look of the stock white rims.
Old Apr 27, 2006 | 07:44 PM
mw66nova's Avatar
Engine: 7.0L
yes, but make sure you paint the center portion of the wheels (where the lugs go) black, or else it won't look right.
Old Apr 28, 2006 | 03:15 AM
iroc-z's's Avatar
Car: 88 camaro rs
Transmission: auto
those black rims look sick
Linson
Oct 24, 2025 02:00 PM
Pac J
May 17, 2020 10:44 AM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
