Taillight mod orange to clear
Old May 19, 2006 | 08:23 PM
PREDATOR's Avatar
Heres my plan, ill get 2 taillights from a junk yard then cut the clear section out of those. Ill also cut the orange out of mine then combine them together. Once i connect them, they'll probably be a little ruff so ill sand the grid line(which is were they'll connect) then repaint the grid lines so you cant tell. I dont know what you use to combine plastic, but i do know you can connect them just like you'd weld metal or something. Heres a before and after shot of what they should look like:
Old May 19, 2006 | 08:53 PM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Transmission: 5 Speed Manual
Axle/Gears: 3.42 Peg Leg
Should look pretty good. I didnt realize that B4C's came with the PI badge on the back, or did you add that?
Old May 19, 2006 | 09:37 PM
PREDATOR's Avatar
It was like that when i bought it, but i am the 4th owner.
Old May 19, 2006 | 10:24 PM
kyles88bird's Avatar
Car: Trans AM
Engine: 305 TBI LO3
Transmission: W/C T-5
Axle/Gears: 3.42 Open
i forget the product name but when we had to rebuild my boss's 72 340 duster grill, we used it(its like a clear liquid that hardneds to look like plastic) to build parts we needed(mint ones were 400$+ on ebay) and painted and u could never tell, ill try to get hte name for ya
Old May 19, 2006 | 10:34 PM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
Just make sure they still light up orange and aren't brighter than they should be and you'll be fine.
It's become a pet peeve of mine to see clear turn signals that light up white. Half the time I want to pull up beside the person and go "you know your
tail lights are broken" and then explain why. If they tell me they're supposed to be like that I'll just say ".....Oh. That's dumb."
As for bonding plastic, acetone works well. There are other things out there, but they all just do the same thing. Melt the plastic and then evaporate, allowing it to harden again. A walk down the adhesive aisle at wal-mart should be all you need.
Old May 19, 2006 | 11:44 PM
Phyte's Avatar
Car: 92 Z28
Engine: 350tpi
I think I'm the minority here, but I like the orange tails and sides. Specially with my bright red Z28. Gives a nice contrast IMO.
Old May 20, 2006 | 08:21 AM
PREDATOR's Avatar
IMO my idea is pretty simple, im suprised no one has done it. I think its a big improvement.
Old May 20, 2006 | 10:40 AM
jn_texas's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
Go for it,- looks pretty darn good. I am otherwise not a big fan of the grid style taillights, but that is really a great improvement.
Old May 20, 2006 | 12:12 PM
Firebat's Avatar
It will look good until the blinker is turned on.
Old May 20, 2006 | 12:23 PM
Firebat's Avatar
Kind of similar subject. Camaro experts - is this possible?
Old May 20, 2006 | 12:33 PM
PREDATOR's Avatar
that could work, but i wont do it. That would require too much work, and once you connect them in your 3 places they probably wont hold to good.
Old May 20, 2006 | 12:55 PM
srdynamics1's Avatar
Car: 91RS_92Z28
Engine: 5.0_5.7
Transmission: WCT5_WCT5
Axle/Gears: 3.08_3.42
Yes. You need to change the bulb holders to all 4 wire styles and wire accordingly.
Ethan L
Good luck with the cutting and glueing of the clear section. I don't think that will work well. Remember that some glues and epoxies will eat the plastic.
Old May 20, 2006 | 07:26 PM
CrazyHawaiian's Avatar
Car: too many ...
You are not the first person to try this, I've already done it but my project is still incomplete because I'm stuck on the corners. Be sure to measure the lights before cutting (measure reverse square and compare to turn signal square, etc), you'll find that they are not all the same measurements. I've also found it much easier to find cheap sets of the older IROC-Z taillights and use the clear portions from those lights. And finally, I would forget about the bulbs, I say convert to LED's and mount them yourself, much better control over the lighting and easier in the long run.
Old May 21, 2006 | 12:57 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Not too difficult. Use polycarbonent which is easily bent into shape with a torch.
The ends can be spliced together with lead ‘H’ channel, which is also easily bent
and paintable. Your finished product will look like GM did it.
“If people drove any slower
they’d be going backwards.”
Old May 21, 2006 | 05:25 PM
PREDATOR's Avatar
Hey crazy hawaiian You got any pics of your work so far?
Bubbajones_ya
Oct 25, 2015 08:01 PM
loud91rs
Oct 5, 2015 10:05 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
92firebirdchris
Exterior Parts Wanted
Oct 1, 2015 01:38 PM
