Lowering problems
Old Mar 13, 2001 | 04:20 PM
matty350TPI's Avatar
Lowering problems
Ok I am going to be lowering my car but I fear for my cat. It sits about 2inches of the ground right now and if I lower it. It will basically have an inch or so. Is there any way to raise the cat higher so I don't tear it off?
1988 IROC-Z T-Top
350 Crate engine
370ft. lb Torque STOCK
5speed Centerforce clutch
Old Mar 14, 2001 | 11:24 PM
Nightcruzer's Avatar
Car: Trans Am
Did you put an aftermarket exhaust? I would check all you exhaust connections, you should have at least 5-6 inches. Maybe a clamp is busted or something.
Old Mar 15, 2001 | 01:10 PM
Yes there is an aftermarket 2 1/2 inch exhaust on the car at this time.
THanks
Old Mar 17, 2001 | 06:34 PM
camaro6spd's Avatar
I want to lower my car 1 inch but all the company's I see only see 1" to 1.5" , 1" is the rear and 1.5 in the front i suspect. Will the 1.5" make that much of a differance. I roads around here a bumpy but a 1" lower will do fine. I just don't want to push it more then that. Where did you guys get your springs and what did they cost?
-Tom
Old Mar 17, 2001 | 08:23 PM
TMoNeE's Avatar
Car: 87 Z28
buy the eibach pro kit.. 1" all around
customblackbird
Aug 15, 2021 10:16 PM
Infested
May 22, 2018 11:56 PM
87iroctheo
Dec 4, 2016 11:47 AM
Street Lethal
Aug 14, 2015 08:25 PM
