Just bought Black ZR1 Rims
Car: 1987 camaro
Engine: 6 cylinder
Transmission: 5-speed
Hey everyone i just bought Black 18" ZR1 rims for my car...they should be here in the next week.
Anyone have any idea what size tire is the best to go with for the front and back to give it a nice stance. They are 18x9.5
and is Skulte the best place to get spacers?
Thanks,
Nick
Thanks,
Nick
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
Skulte makes the best adapters money can buy.
run a 275 up front and a 285 out back. that would look sick!
Car: 1983 trans am
Engine: Vortec 350 w/ a comp cam
Transmission: B&Mth350 2800holeshot
Axle/Gears: 10bolt 3.23's
i love how 315's look in the rear of any car, if its possible. but 285's are sweet too. what kind of tires are you planning on running?
Car: 1987 camaro
Engine: 6 cylinder
I think im going to run Nittos in the back..i dunno about the front though i might just run a goodyear up front or something
Car: 85 T/A
Engine: l98 ,cam,exhaust
Transmission: beefed up 700R4
Axle/Gears: 2000 ss 3.42s
i have 17x8.5 up front and 18x9.5 in the rear with a 4th gen rear. the front rub as it is and there 245/45/17 putting a 275 up front i can tell you won't work and thats with my 2' spacres from skult. as for the rear i have 275 40/18 and they look great i would of went bigger but the would stick out a little to much, whats the biggest you can get on a 9.5 inch rim?? if you want pics let me know i can get them.
Car: 1987 camaro
Engine: 6 cylinder
yea please post pics!
Should i go with a 245 up front? i know im doing a 285 in the back thats positive its just the front im dealing with.
o and do the 4th gen rears bolt right up? i wanted disc breaks in the back and plus with the ZR1 rims i wouldnt need spacers out back. so i wanted to see if a good buy would be the 4th gen rear
Last edited by Yellow87Cam; Jun 24, 2006 at 11:09 AM. Reason: Automerged Doublepost
Car: 1991 Z28
Transmission: WC T5
Axle/Gears: 3.73 Posi
Skulte does not make the best adapters because his are not hub-centric. They are lug centric. I have them and I get vibration at highway speeds.
As for 275's up from. I have them on my car right now. Aswell as 295's on the rear. All on 97-00 C5 wheels.
Car: 1987 camaro
Engine: 6 cylinder
matt-p are u running spacers?
if so what brand?
i heard a lot of good things about skulte yet also that there not needed cause of price and u only need them in your road racing..i was thinking of getting the billet-aluminum ones on ebay but i heard bad things about that also.
Any help would greatly be appreciated.
Can u post pics of ur tires and rims on ur car?
thanks
if so what brand?
thanks
Car: 1987 GTA
Transmission: 4L60e
I'm interested in which hub-centric spacers to get as well. I was under the impression that skulte was the place to go....now I'm confused.
Car: 1992 Camaro z28
Engine: 350 HSR
Axle/Gears: 3.42's
If ya don't wanna second guess yourself go with skulte, ebay is great but there is def a bigger chance of something goin wrong.
If ya buy from ebay like my friend he seemed to be worried all the time, every little bump or sound he head he would stops to check the wheels. He then bough some from skulte and even though neither gave him problems(could be the exact same) he dosen't stop all the time now with the skulte adapters.
Spend the money and go with a name thats been around a while or take a chance with the new guy with lower price it really comes down to what cha got in your pocket at the time of purchase.
IMO
Car: 85 T/A
my 245s in the front rub but only while turning as if your doing a U turn thats it you probaly could go bigger but your gona get more rub on your tires.
Car: 85 T/A
hmm weird i posted pictures before and copied URL i'll have to see how to get them on sorry.
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
wow thats weird, i know alot of ppl on this board running 275's with NO problems what so ever. i have 245 16's on my car and they dont rub at all. and a 17inch tire would be the same overall diameter.
i'd probly go same tire all around...with 18's you have tons of choices, but i'd go 265's up front.. either 265/40 or 265/35. probly the 35 as it would be smaller in diameter and would fit better. or if you want, 255/40's.
then rears i would try and squeeze 295/35's on
if you dont like that then definately 275's or 265's all around
Car: 91 Z28
Axle/Gears: 3.73 Hawks 8.8
Skulte is the way to go...
I've been running them for years and never had a failure or vibration problem of any kind. Only issue I've had is Discount tire won't touch my wheels while on the car because they feel adapters/spacers are unsafe. So I just take the wheels in the back of the truck if I need something done.
Hubcentric vs Lug Centric. Doesnt matter, as long as you have em tight, they will line up, thats why there is a recess in the Skulte adapter, so when the lugs tighten, they center up.
Car: 85 T/A
i have a few more that i will put in the front tire looks linka jacked up because i just put a new engine in the car and haven't gotten the weight to lower it down yet.https://www.thirdgen.org/forums/atta...1&d=1149566711https://www.thirdgen.org/forums/atta...1&d=1149566692https://www.thirdgen.org/forums/atta...1&d=1149566665
Car: 89 RS
Transmission: TH350
Will your wheel adapters cause vibrations?
Our billet adapters are hubcentric, and also have conical lugnut seats that center the adapter to the hub. If the adapters are first finger tightened in a star pattern, then torqued to 30 ft-lbs, and finally ftorqued to 85 ft-lbs, the adapters will center themselves to the lugnuts. Other adapters that use the older mag-wheel style shank and washer to bolt the adapters to the hub will have some slop, and may cause vibrations at higher speeds. We also recommend wheel-centric lips on any adapters that are thicker than 3 inches, especially in the front. Under 3 inches, we have never had any vibration issues, although we can add the wheel centric lip if requested on custom adapters. We use the SPD billet wheel adapters on our '89 Camaro, which regularly sees high-speeds at the race track without vibration.
Seems like these guys are the way to go for a few reasons. Now I need to order a set.
86IROC112
Sep 7, 2015 01:37 PM
