Best store bought product for cleaning carpet?
Old Jul 18, 2006 | 11:22 PM
TunedportL98's Avatar
Hey guys, whats the best store bought product for cleaning carpets in cars? Does anyone have any favorites? Thanks
Old Jul 19, 2006 | 08:33 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Try Greased Lightning "Orange Glow". You can get it cheap in the automotive section of Wal Mart.
Do this on a dry, sunny day.
Spray it right onto the carpet, and then hit the carpet with a little bit of water. Scrub it.
After you scrub for a while, get a hose and a shop vac, and spray it with the hose, then quickly vac it up. This will lift the dirt and pull it out pretty effectively. This is probably about the best you can do other than a steamer.
Do that a few times until you're sucking up clean water, then leave your doors open with a box fan blowing on the floor for a couple hours. This will make sure the carpet and the padding will dry out properly.
Old Jul 19, 2006 | 05:20 PM
Raiderfan's Avatar
Car: '92
Also try the .99 cent WAL-Mart brand spray foam carpet cleaner, it comes in a pink can.
For those stubborn stains I like to use Bissell carpet cleaner, it's the liquid type made for steam cleaners (red bottle), this stuff will remove just about anything.....
Old Jul 20, 2006 | 05:58 PM
FlyinLow89's Avatar
Car: 1995 Formula/2001 GTP
Engine: 5.7 LT1/3.8 Supercharged
try mr clean Oxy clean or whatever its called for stains in fabrics....works great
Old Jul 24, 2006 | 09:37 AM
MNformula350's Avatar
Tuff Stuff, Has worked great on everything I have tried it on.
Old Jul 24, 2006 | 06:54 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
I've used Simple Green and it has worked great.
Old Jul 24, 2006 | 08:36 PM
LT1LE's Avatar
Car: TWO 1992 CAMAROS 1 Z28 AND 1 B4C
Engine: 1 LQ9 AND 1 LS3
Transmission: 1 T-56 AND 1 6L90
Axle/Gears: 1 4.11 AND 1 3.31 (DANA 44)
BLUE MAGIC.... You can get it from Wal-Mart or any auto parts store....
Old Jul 24, 2006 | 08:48 PM
NoItsNotForSale's Avatar
Car: 87 & 89 Iroc's
Engine: 5.0 - 5.7
Transmission: 700R's
Axle/Gears: 2.77 - 3.70
Same here good stuff.
Old Jul 24, 2006 | 10:11 PM
dcjredline's Avatar
Car: 1989 Formula 350
Tuff Stuff for spots but when I did my formula I did it the Jim method except I took the carpet OUT and used the Armour All Oxy stuff. WORKED AWESOME! My Calais is going to get the same treatment soon too.
Old Jul 24, 2006 | 11:22 PM
maroon88iroc's Avatar
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
damn just about everyone of yall posted a different product lol....
Old Jul 25, 2006 | 05:23 PM
Raiderfan's Avatar
Car: '92
lol, I have also used Tide w/bleach (with the carpet out).
Just dust the carpet with the Tide and lightly spray with water, let it sit a while and give it a good dose of water to rinse.
Old Jul 25, 2006 | 05:45 PM
CG_1985_Z28's Avatar
Car: 1985 Z28 camaro
Engine: lq4
Transmission: th350
tuff stuff
I use "tuff stuff" it seems to work very well, you can get it at advance auto parts, auto zone and walmart I think has it.
Old Jul 25, 2006 | 09:29 PM
83camaroMN's Avatar
Car: 1998 Mustang
Engine: 3.8L V6
Transmission: Automatic with overdrive
Axle/Gears: 2.73:1 axle ratio
what he said SIMPLE GREEN is the best. It cleaned my int. reay good took the stains out that some other cleaning products couldnt
Jeremys87
Jul 14, 2022 09:08 PM
lee01
Apr 9, 2016 01:56 PM
86IROC112
Sep 7, 2015 01:37 PM
johanlindgren
Aug 16, 2015 12:16 AM
