Spray on tint removal
Old Jul 20, 2006 | 09:14 AM
necromancer1967's Avatar
Car: 88 Chevy Camaro IROC-Z
Engine: L98 5.7L 350 MAF TPI
Transmission: TH700R4
Axle/Gears: BW 9bolt/3.27 gears
Not sure if this is for this section. I apologize if it's not. I just picked up an 1988 IROC Z L98 from a used car lot. Previous owner applied window tint spray, or something like it, to the rear lenses as well as the front turn signal lenses. I'm attempting to remove this coating and restore the lenses. I searched several locations on the web. One site, a plastic modelers web site, had several different ways of removing paint from plastic. The least caustic way was to soak the lenses overnight in Simple Green. Tried it, but it had no effect on the spray-on tint. They also suggest soaking the piece in brake fluid. I think it might work but also might cloud the plastic. Any suggestions for getting this mess off and restoring the lenses to their original condition? Also I would like to thank EVERYONE who participates on this site. You all contribute tremendously in your knowledge and expertise. I can't thank you all enough for the help I have recieved.
Old Jul 20, 2006 | 09:58 AM
luisote's Avatar
Car: Camaro IROC-Z 1987
Engine: 454 BIG BLOCK
Axle/Gears: 3.42 gears Posi trac
try plast-x from meguiar's or a little bit of thiner in a small part to see if it dn't do something to de plastic, but I think plast-x will work for u
Old Jul 20, 2006 | 10:02 PM
DJCobol's Avatar
Car: '89 Black IROC 'vert
Transmission: 700-R4
Axle/Gears: 2.73 posi
Wetsand with 1500-2000 grit sandpaper until its all off, and then polish them up with some 3M rubbing compound.
Edit: or buy a few bottles of rubbing alcohol. It will take it off eventually, but it will take a long time.
Old Apr 27, 2007 | 12:09 PM
Re: Spray on tint removal
tried plast-x, no joy, tried just wet sanding, took forever. Finally used brake fluid and worked with it very fast and washed it off thoroughly. then wet sanded and then polished up with plast-x. did very well but had to hand paint the black trim lines. saved alot of money not having to buy new lenses. sorry no pics, but thanks a mil for the ideas!
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
Fronzizzle
Feb 9, 2017 09:31 AM
Stroopwafel
Sep 11, 2015 06:38 AM
TheExaminer
Sep 6, 2015 11:40 PM
