running stainless & anodised pcv line???
Car: 1988 IROC 5.7 Money Pit
Engine: (being built; modified TPI ZZ4
Transmission: 2200 stall/ stage 3 700R4
Axle/Gears: freshened 3.27 in 9.bolt/
I was thinking of running a length of stainless steel hose from the pcv valve with colored anodized fittings on my L98 engine, so I ran through all the photo's in the engine pic gallery and didn't see anyone having done this.
I'm assuming that there's no reason not to. The question I have, as I've never run stainless tubing before, is if there might be any suggestions on a nicer way to set up the fittings other than slapping on one foot of hose and two colored clamp ends?
Did I explain that correctly?
Nitro
Nitro
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
If you want to see what it looks like, just pick up a Hot Rod magazine from the late 80s. Back then everybody had stainless lines (or fake braided stainless lines) with a different colored fitting on every line.
Terrell351
Jun 13, 2021 01:13 PM
theshackle
Mar 5, 2017 06:37 PM
