Pressure Washed my Engine Bay this morn...
Old Sep 18, 2006 | 06:19 PM
Psycho_91Camaro's Avatar
Car: 1991 Camaro RS
Engine: THE LT1 SWAP SHALL BEGIN!!!!
Transmission: 700 R4
Axle/Gears: LSD! =(
Got up this morning with 1 thing in my mind, to WASH THAT DIRTY ENGINE BAY!!!! here are some pictures of my success, this is as best as I could do... its not as clean as I wanted it but hey what are ya gonna' do?
Old Sep 18, 2006 | 06:32 PM
90 white Z's Avatar
Car: 90 iroc
Engine: 305 tpi
wow that looks really good could almost pass for showroom condition!! i was going to do that with mine but im too scared lol..But how many miles do you have on that beast
Old Sep 18, 2006 | 06:48 PM
Car: 1991 Camaro RS
Axle/Gears: LSD! =(
I was scared too, I removed the air cleaner and tied a garbage bag around the TBI unit and then I just said... "hey if I mess it up I wont be able to drive it anyway! because I don't have enough money to register it again or to smog it!!!!" so it'll be sittin in the garage for a while...
I first turned the car on for about 15 min... then let it cool down for like 10 minutes and then sprayed some simply green all over... then waited for like 5 minutes and then sprayed again then went over to set up my pressure washer and WASHED AWAY! and continuously sprayed simple green.
The car has 136,XXX miles.
I then turned it on and let it run for about 5 minutes then shortly after I dried it with a terry cloth, and sprayed WD40 and took some pics for you fine folk!
Old Sep 21, 2006 | 11:28 AM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
Real good, however what really makes it look neat and clean is you not having any paint peeling off or any really scratched surfaces. Your intake manifold for instance, nice even paint on it, no black and cast aluminum like mine
Good job
Old Sep 21, 2006 | 03:10 PM
Midwest Muscle's Avatar
That would easily pass for 100K less mileage than it really has - Nice work!
Old Sep 21, 2006 | 03:27 PM
Car: 1991 Camaro RS
Axle/Gears: LSD! =(
thanks guys, I still need to pressure wash the bottom of the engine...
Old Sep 21, 2006 | 06:00 PM
gcgarner's Avatar
Car: '92 T/A WS6 Vert/1956 Chevy Nomad
Transmission: 700r4 w/ Transgo Kit
Axle/Gears: 3.42 LSD
How much pressure did you use? My p-washer has three nozzles ... "Delicate", "General" and "I'll Rip Up Asphalt Beeatch!".
Old Sep 21, 2006 | 06:59 PM
Car: 1991 Camaro RS
Axle/Gears: LSD! =(
It depened on the area where I had to use it, and what sensative parts contained and how much grease and oil was present.
Old Sep 23, 2006 | 04:02 AM
Iroctopless's Avatar
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
Awesome job! Beutiful results.
Old Sep 23, 2006 | 05:18 AM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
looks kick ***! definately looks like she has half the mileage, if that. props.
Old Sep 23, 2006 | 08:49 AM
Demon355's Avatar
Good job dude, looks real nice! I need to do that to my engine bay.
Old Sep 23, 2006 | 09:27 AM
n2omike's Avatar
Car: 86 WS6 Trans AM/ 95 Trans Am
Engine: 305/Lt1
Transmission: 700r4 / 4L60
Axle/Gears: ? / 3:23
What everyone else said! I guess I should do the same to mine after seeing yours.
Old Sep 23, 2006 | 12:09 PM
Car: 1991 Camaro RS
Axle/Gears: LSD! =(
Yeah, it's actually real fun just be careful of open areas and sensative electrical equipment and you should be fine, I mean sure your pouring oil into the enviroment, but hey that THIRD GEN needs to loook good!!! for the enviroment! it's a win win deal!
Old Sep 23, 2006 | 12:14 PM
Car: 1991 Camaro RS
Axle/Gears: LSD! =(
I mean, just look at IROCTOPLESS!
Man and Machine and of course Nature can be 1 with each other!
Just my !
Old Sep 23, 2006 | 01:54 PM
gray89vert's Avatar
Car: 1989 RS convertible
Engine: 305 TBI LO3
Transmission: TH-700-R4
Axle/Gears: stock axles 3.73 LSD
lmao that made my day "I'll Rip Up Asphalt Beeatch!" lol
Anyways. Very very nice job on the cleaning!! I am really impressed. Simple green is really good stuff. I can get it for free from my dads work so now I know how im going to clean my engine next time i get the pressure washer out.
EDIT: Another thing I would like to say is that your car looks really good in black primer.
Old Sep 24, 2006 | 12:15 AM
{TKM}Tom's Avatar
Car: 84 Trans AM
Engine: 305 HO
Transmission: one that dont work so well
looks nice
if i just wanted to rinse my engine bay how would i got about doing it. just let the car run while i rinse away
Old Sep 24, 2006 | 02:11 AM
Axle/Gears: 3.08
Just my !
Be careful even if your just giving it a rinse . . .
- There are some areas (electrical) that don't like any water. Water with pressure can be even worse in those sensitive places.
- Water on a hot engine can be risky. Some say they like to wash a hot engine because the oil and grease residue comes off easier. I'd rather have my engine just warm and let the chemicals (Simple Green or Spray Nine) do their work on the grease. Then, use easy to aim, gentle, controllable water pressure. Practically no more than out of a garden hose (sometimes even without a nozzle on it).
- plus a running engine has moving parts (like fans, etc) that can cause dirty water to spray, getting on areas you don't want.
A helpful hint when cleaning is, after the chemicals have had a few minutes to penetrate dirty areas, aggitate those hard to get places with a toothbrush or paint brush. Then when rinsing, get in those place again with a soft brush to help wash away everything.
When done, due to using any chemicals (even mild ones) I like to treat all surfaces, eg; wax any painted areas, applying protectant to any plastic or rubber (hoses, covers, etc). Also relubricate any areas that may need it, eg; exposed mechanical linkages, hinges, etc.
Then finish off with a beer or two!
Old Sep 24, 2006 | 02:36 AM
{TKM}Tom's Avatar
Car: 84 Trans AM
Engine: 305 HO
thanks for info iroctopless i didnt mean the whole engine i know i didnt say that but i just want to rinse off the inside of the fender wells and stuff lot of dirt
Old Sep 24, 2006 | 08:25 PM
Aquafied Iris's Avatar
Car: 1987 Pontiac Firebird
Engine: 2.8L V6
Transmission: 5 Speed Manual
x2
Old Sep 24, 2006 | 10:37 PM
ecetim's Avatar
Car: 92 RS B4C - needs lots of work!
Engine: 5.7L L98
Transmission: 700R4?
Thanks for the details, I'll want to do this eventually...
Old Feb 9, 2007 | 10:27 AM
Car: 1991 Camaro RS
Axle/Gears: LSD! =(
ahhhhhhh I pressure washed my engine again and now the damn thing idles at 1k and now it doesnt want to start up!!!!!!!!!!!!!!!!!!!!!!!! and I need to get to work
Old Feb 9, 2007 | 01:34 PM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
I use to do it all of the time when I detailed cars and never had a problem. Just keep the wand moving and don't spray the distributor cap or any major electrical parts with a lot of power. I do my cars at least once a season.
Old Feb 9, 2007 | 02:24 PM
Stevo's Avatar
Car: Pair of 92 Z28s
pull off the distributor cap and blow it out with compressed air.
Old Feb 9, 2007 | 02:59 PM
XxGeinNothingxX's Avatar
Car: 1991 Camaro RS
Engine: 350 bored .30 over
Axle/Gears: Posi 342
Haha ! I guess that last one is probably the one I used to wash the outside of my parents truck a while back, took the pin striping off.
The engine bay looks really great man.
Old Feb 9, 2007 | 04:12 PM
Thestriped1's Avatar
Car: 89 2.8 RS
Engine: the 2.8
Transmission: 700r4 auto
Axle/Gears: stock one wheel squealer
i want to pressure wash mine its covered in grease from the previous owner. im terrified tho its my only ride and i dont have the cash to fix anything if i break it. I heard about dealerships using a steam set up and thats supposed to be top notch. The steam and humidity loosens everything while the psi blast the stuff off.
it
Old Feb 10, 2007 | 09:06 AM
Car: 1991 Camaro RS
Axle/Gears: LSD! =(
Looks like I damaged the MAP SENSOR!!!!!!!!!!!!!!!!!
wORD OF ADVICE
NEVER BUY AFTERMARKET MAP SENSORS OR IGNITION CONTROL MODULES!!! USE GM!!
Reddeath210
Oct 6, 2015 08:20 AM
AkDrifted
Aug 17, 2015 07:45 PM
jahblah
Aug 12, 2015 05:54 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Kaweh
Aug 9, 2015 02:54 PM
