Foose Nitrous wheels
Old Nov 13, 2006 | 04:10 PM
Chevy3Girl's Avatar
Car: 92 Camaro RS 25th Anniversary
Engine: Built 400
Axle/Gears: 3.73 gears
I probably put this in the wrong seciton....
I was just wondering if anybody knew if they made these wheels that would fit a 92 Camaro RS? I looked on eBay and they have some 15s but the guy said I would need a 4.75 bolt pattern and all he had was 4.5. Just wondering if anybody knew anymore about them, cuz I have no clue, I'm learning. thanks for any help and sorry if it's a stupid question.
Katy
http://cgi.ebay.com/ebaymotors/4-15-...spagenameZWDVW
Old Nov 13, 2006 | 04:28 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
sorry those aren't going to fit. snazzy though. why 15's?
look for a set that has a 5x4.75 inch bolt pattern.
Old Nov 13, 2006 | 04:30 PM
Chevy3Girl's Avatar
Engine: Built 400
That was just one set... the 15s. I was probably going to go bigger. But I didn't know if they even made them in that bolt pattern period.
Old Nov 13, 2006 | 04:39 PM
BADNBLK's Avatar
COTM Editor
Those wheels can be bought with a 5 on 4.75 bolt pattern, just need to look a little harder. I would use at least a 16" wheel to really make that style of wheel stand out.
Good luck!
Old Nov 13, 2006 | 05:54 PM
camarojustin's Avatar
Car: 88 camaro
Engine: 355
Axle/Gears: 3.73 posi
I have 18 inch foose nitrous 2 piece wheels ( the ones without the rivets )
the 2 piece are a custom wheel you can order with any backspace and they do come in the right bolt pattern
The nitrous wheel with the rivets does come in the right bolt pattern but not the right backspacing for a camaro
Old Nov 13, 2006 | 05:59 PM
Car: 88 camaro
Engine: 355
Here's the link to the thread I started on them
I was gonna just post the pic but I can't cause it's already been posted
https://www.thirdgen.org/forums/auto...t=foose+wheels
Old Nov 13, 2006 | 06:05 PM
purpleZ-28's Avatar
Car: 85 Z28, 88 GTA, 68 Cutlass S
Engine: 305TPI X2 ;), Chevy 250
Transmission: T5, 700R4, powerslide >:(
Axle/Gears: posi, and posi w/discs :D.
since foose is a custom wheel shop id think they would cater to all sizes and patterns. i know that boyd does that. call em and find out.
Old Nov 13, 2006 | 10:50 PM
Kandied91z's Avatar
any billet wheel company can build their wheel to suit your vehicle specifically. call direct.
Old Nov 28, 2006 | 10:47 AM
Chevy3Girl's Avatar
Engine: Built 400
What backspacing would be required?
Katy
Old Nov 28, 2006 | 11:26 AM
super_kev's Avatar
Car: '85 TA
Engine: Aluminum Fuelie
Transmission: Mother of All Manuals
For a 8" wide wheel, use stock 4.5" backspacing; it will allow you to rotate the wheels if you want to.
Old Nov 28, 2006 | 06:11 PM
Car: 88 camaro
Engine: 355
or if you want to run a 10" wide rear you could go with 6" Backspacing and have the 8" wide with 4.5"bs in the front
Old Nov 29, 2006 | 11:02 AM
Chevy3Girl's Avatar
Engine: Built 400
Ok so I found some Foose nitrous with rivets 18"x 8.5 , 5 on 4.75 bolt pattern with a 4.5" back spacing. You don't think those would work?
Thanks for any help.
Old Nov 29, 2006 | 11:07 AM
super_kev's Avatar
Car: '85 TA
No, they will. However, the wheels will stick out .5" more than stock and sit flush with your fenders (you won't have a tucked-in look). An 8" wheel w/4.5" b.s. gives you 3.5" from the hub out, while 8.5" w/4.5" b.s. will give you 4" out from the hub.
Old Nov 29, 2006 | 11:11 AM
Chevy3Girl's Avatar
Engine: Built 400
Ok well that rocks... I think I found my wheels. Thank you so much for your help!
Katy
Old Nov 29, 2006 | 11:15 AM
super_kev's Avatar
Car: '85 TA
Are these used wheels? If not, I would ask for 5" backspacing when ordering.
Old Nov 29, 2006 | 11:35 AM
Chevy3Girl's Avatar
Engine: Built 400
Actually they're on eBay.
Katy
Old Nov 29, 2006 | 01:10 PM
SlowCamaro88SC's Avatar
18" is much better than 15".
If I were buying aftermarket wheels for my thirdgen, I wouldn't even bother w/ anything under 17"
Old Dec 3, 2006 | 12:10 PM
fmacon1992's Avatar
Car: 1992 RS
Post pics when you get those on i would like to see those on the ride!
obeymybird
Exterior Parts for Sale
Nov 3, 2015 08:10 AM
drptop70ss
Oct 4, 2015 09:44 PM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
