Greased Lightning
Old Nov 28, 2006 | 09:03 PM
1bad86's Avatar
Car: 1986 IROC-Z
Engine: 305 T.P.I.
Greased Lightning
Ok, I was thinking about using greased lighting to clean my stock wheels really good, Ive searched it on these forums and most say it works pretty well,however on the bottle it says not to use on aluminum or clear coated surfaces has anyone ever had any problems with it taking the clear off their wheels?
Thanks,
1BAD86
Old Nov 29, 2006 | 04:53 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
It won't strip the clear, just cause it to fog over if the wheel is hot. Or so has happend to me in the past.
Any of those type cleaners are the exact same product with a different labe basically.
The main ingredient is usually sodium hydroxide (lye, caustic soda) which is what makes it the nasty crap it is.
JMO though..
Old Nov 29, 2006 | 05:09 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
I've tried wheel cleaner before. All it did was burn my eyes...
Old Nov 29, 2006 | 07:25 PM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
Yes agreed with deadbird. If you use is on bare aluminum....it will fog up. I went to clean my motor, I have a polished Plenum, and dist. cover. I paid hell to get it to shine again. I had to get my buffer out and use some bullit aluminum polish.
I also have used the mothers power ball and the polish that comes with it. Even though I had the clear coat on my stock rims.....THEY CLEANED UP REALLY WELL!!
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
Fox118
Members Firebirds
111
Jan 26, 2016 07:17 PM
IROCZDAVE (88-L98)
Sep 22, 2015 02:22 PM
Numbah-1
Sep 12, 2015 08:57 PM
dyeager535
Aug 28, 2015 08:10 AM
